• Server migration complete
    In the early morning of September 26, 2020, our migration to new servers was completed.
    Things seem to be working as expected, but if you notice any issues including not receiving email notifications,
    please vistit this thread for more details
Coolant Refill
f10088
Chicago
Golf
I had to replace the radiator on a 2015 Golf following an incident with a curb. When refilling the system I could only get about 4.5 liters into the system and the specs are that it should take 6.5 liters. Is it possible the system retained 2 liters even though the rads drained completely?
ticaf
baltimore, MD
2015 Golf SW S Manual TDI
Oh yes, you won't completly drain the coolant by just draining the radiator.
You should vacuum fill, use VCDS or unplug the switchable coolant pump to get the coolant to circulate.
Some here, just refill and kept refilling while air gets out over a few days.
f10088
Chicago
Golf
Thanks for the response. I don't have a vacuum kit and want to ensure that the system is filled to the correct level.It comes up to temp fine and holds at 200 degrees so I might be overthinking this?
JM Popaleetus
Connecticut
Signature.
I would personally do another drain and fill, and call it a day.
But, as long as temps/level are fine in the interim, you should be good.
f10088
Chicago
Golf
Is the switchable pump the one under the engine? I have it up to temp but the hoses on the drivers side :larger diameter ones) don't seem to have any heat in them. Thanks
ticaf
baltimore, MD
No, on the side, timing belt driven. If you have already driven the car to temperature, you probably should be fine. Just watch the coolant level. You'll get a MIL if coolant goes too low.
adjat84th
Virginia Beach, VA
'01 Jetta TDI/'15 Golf TDI
You know, I've had the coolant drained a couple of times on my car and never thought to do it this way! It makes total sense that the coolant never dropped in the reservoir until up to temp since the shroud doesn't move until all the way warmed up. If I recall, it took several top ups to finally get all the air out.
