Loaf
My 1998 has a scraping noise at idle. I crawled uner it today and the water pump feels loose. There is 1/8" or so of play, but the pulley bolts seem tight. There is small leak coming from the underside of the pump.
I had a new timing belt put in about 20,000 miles ago, and the mechanic did not replace the pump. I'll be doing the work myself this time, but it looks like I should remove the TB to access the water pump.
My question for now...
I need the car to commute to work. Can I let the leaky, loose water pump go for a while, or does this need immediate attention?
