zeoalex
Hi All,
I've been working on my girlfriend's car (2014 passat TDI SE) that had some goofy stuff going on - outside air temp failed (MFI reads ---F), intermittent fuel gauge failure (that seems to be more sustained now since it started at the beginning of winter) and a flashing/sustained TPMS light. I swapped the OAT sensor assuming that maybe the other failures were related by needing OAT for correction calculations or something to that effect and obviously that didn't fix the issue.
After spending time reading through the wiring diagrams and noticing that the OAT and the coolant level sensors were on the same ground line back to the cluster, I pulled the coolant level sensor, to check continuity/resistance between the shared ground. To my shock, the collector started dripping. That led me to some further research and finding that coolant migration has apparently long been an issue with VW's with this style of coolant bottle. I went and pulled the fuel pump connector and saw some coolant had made its way back to that connection as well. That would explain the fuel gauge issues.
My question to the class is this - is this something people are seeing on the NMS chassis vehicles? Obviously, this was a huge issue in the early 00's/B5 era, has VW not learned their lesson? Do I have any prayer to get VW to cover this as a goodwill fix, as I can't seem to find a TSB or recall related to this? or am I going to be SOL and have to eat a few grand worth of potential harness repairs?
