Carol in Maine
- Joined
- Jan 18, 2006
Hello, I am the original owner of this car with 49,300 miles. 9 days ago the speedometer started bouncing. The next day the speedometer malfunctioned again and then dropped to zero while cruising along at 65mph. Just by coincidence I turned on the headlights to illuminate the instrument panel and the speedometer returned to 65 but not for long.
Relating this information to my brothers (both TDI owners) they researched TDICLUB and discovered the COOLANT MIGRATION problem. I popped the hood , took off the coolant sensor and the 2 pins were sitting in a puddle of coolant. I left the sensor unplugged and waited for my car appointment at the VW dealer where the car was purchased and has been serviced. At the appointment two days ago I was told that the coolant expansion tank was defective and leaking around the pins and a new one is on order. The service advisor said that the technician could not duplicate the speedometer problem during 2 test drives. I showed them a copy of the TSB dated April, 2001 and was told that the coolant migration problem does not exist anymore as “VW has solved that problem” On my way home, the speedometer dropped to zero and I returned to the VW dealer to document the situation. The service advisor, technician and myself took the car for a drive with a scanner/computer hooked to the underside of the dash. The only information I could understand from their conversation was that the scanner/computer was not registering any speed while the speedometer was at zero. Another interesting thing happened about 2 miles into the trip…the door locks locked, much later than normal.
They scheduled an all day appointment for this Friday and was told that the car is safe to drive. They said that they needed to study the wiring diagram. On my way home, the door locks once again malfunctioned and two new problems arose….the odometer and trip meter did not function while the speedometer was malfunctioning. Of course, I called the dealer and told them the 2 new problems.
Does anyone know if the coolant migration problem still exists or whether VW has solved the problem? Any comments or suggestions?? I would like to have more information with me when I return for my Friday appointment.
Thank you!
Carol in Maine
Thank you!
Carol in Maine
