JohnJTDI
I have a major coolant leak drivers side under the vehicle. Any ideas?? 1.9 tdi 2005.5 jetta
Leaks all the time; if there is enough coolant in system.Does it leak while the engine is running or once it’s been warmed up for a while and then you turn the engine off?
. Need part no. For elbow.Looks like I need a new PM66-GF30; ??elbow in coolant line about 1.25” in diameter w/a small nipple(about 1/4”) off the 90 degree bend?? Pm66-gf30 is apparently other things as well?? Is located in the upper engine bay on drivers side, front of engine. And is leaking.
Also where to get a new one??. Need part no. For elbow.
OEM parts for cheaper than the dealer. https://www.idparts.comAlso where to get a new one??
Thanks for all the help; IDParts does have the part!!OEM parts for cheaper than the dealer. https://www.idparts.com
Thanks to all who responded!!!Part came in 2 days-no more coolant leak.
