Secondary air injection and exhaust gas recirculation are both still in wide use today. And some that did go away, came back.
There is a WHOLE lotta "not invented here" syndrome alive and well in the auto industry. Achates power is a case in point. I've been following them for quite a while and they have plenty of data showing that their opposed piston diesel engine is more efficient than the standard 4 stroke diesel and can be made today to meet the future Ultra low nox and PM regs for California. The only somewhat commercial variant of it being developed (that I know about) is a combat engine for the Army.It isn't always a given that an add-on engine modification has an equal chance of showing up on the assembly line.
.....snip.....
As others have pointed out, vehicle mfg's are paying their own engineers to step around patent pendings, so why should they pay shade-tree inventors a percentage of their sales?
KilljoyThat garbage has been around for many years. Mercer energy bit into it and had the pistons done on 2 G399 cat natural gas engines running generators. Didn't increase efficiency, or reduce any emissions. No reason to believe it does anything for a diesel either. Besides that if it did work every oe would be using it. Meeting emissions was one of the biggest packaging, cost intensive things they had to deal with. If simply putting a bunch of dimples in pistons would have yielded anything real reductions it would have been done.
logical fallacy detectedBesides that if it did work every oe would be using it
idk... if you watched the video linked right above your comment, it seems theyre doing more than "putting a bunch of dimples in pistons"If simply putting a bunch of dimples in pistons would have yielded anything real reductions it would have been done.
The coating is new, there weren't any coating used on the g399 engines, however coating pistons isn't new, nor is coating the combustion chambers. Changing compression ratio also wasn't done, although I can see rhe basic benefit, lower combustion temps/ pressures leads to lower n0x emissions. One of the reasons cooled egr was introduced first. Displace some oxygen and get a colder combustion event. Not as efficient and won't make the same power vs an engine that doesn't have egr. Hence why egr is turned off at a certain throttle/load.logical fallacy detected
argumentum ad antiquitatem
the ring is different, it has a coating, CR is different, etc.
hell, if it was just putting dimples in your piston, everyone would be pouring ball bearings into the intake manifold right off the lot!
Even if it was proven miracleware, what would be the ROI for rebuilding a perfectly good engine? 400,000 miles?I don't see guys lined up around the block to buy these miracle pistons.
Depends on the engine, use, upkeep. 400k would be a pretty short life for an otr engine . Don't quite know how miles translates to hours in equipment, but on average somewhere between 8-10k hours would be a general idea for rebuild. (Application dependant.)Even if it was proven miracleware, what would be the ROI for rebuilding a perfectly good engine? 400,000 miles?
60mph x 8-10k hr = 480-600k miDon't quite know how miles translates to hours in equipment, but on average somewhere between 8-10k hours would be a general idea for rebuild.
