Cool piston tech
Zak99b5
Albany NY
2003 Jetta TDI
im aware, just pointing out how a conglomerate like bosch can be petty. so no doubt the others are like this too
Not sure there is a patent on dimpling anything. Maybe the specific pattern Shysters of Air use is patented, but not the general concept.
turbobrick240
maine
Let's not forget that there's a whole world of diesel engines outside of passenger vehicles. Even if there was some big strange conspiracy to keep these miracle pistons out of passenger cars, industry as a whole would jump all over an 8%, 20%, 50% whatever increase in fuel efficiency.
adjat84th
Virginia Beach, VA
'01 Jetta TDI/'15 Golf TDI
Doesn't sound any quieter than what's normal. The skinny old white guy with the beard was going on and on about how quiet those pistons made a diesel in an earlier video.
The EA288 has fairly low compression already, that and the two pilot injections makes a very quiet operation. I wonder how much compression drop there is with the dimpling.
x1800MODMY360x
AZ, USA
2013 Passat TDI SEL
I think the car is deleted, not sure if straight pipe or to muffler. But at idle it sounds to me like a non deleted engine.
Lightflyer1
Round Rock, Texas
2015 Beetle tdi dsg
I will consider these kinds of things when they arrive in production vehicles. I see ads all the time on new miracle engines and such. For the most part you never see them make it to a production vehicle. Fun to read about but have little expectation they will ever make it into a vehicle that is mass produced and out for sale.
Boosty
Indiana
04 Golf GL
I watched the vids linked in this thread and was reminded of the aftermarket heads sold for 2 stroke dirt bikes that had been dimpled, increasing power and etc as alleged in these vids, however this 2 stroke shenanigans I recall was decades ago. If it works I'm all for it, a lifetime lasting 20 percent power or efficiency boost is worthwhile in my book.
dieseldonato
Us
2001 jetta
None of this is "new" it's been around the block time and time again, and never gains any real traction.
Yep, solenoid operated port EFI was brought about in the mid-'50s from Bendix, but it wasn't until the late '60s when Bosch got a hold of it and actually made it work reliably.
I think VAG's work on the G-charger was a decades old idea before they first got it working in production in the late '80s.
BEWtheDEW
Montana
2005 VW Jetta Wagon; BEW; 5 Speed
From this SAE paper it sounds like these pistons may increase both fuel efficiency and soot formation. Seems counterintuitive, but the increase in soot may be why manufacturers haven't jumped on board.
Huh. That’s interesting. I’m sure they might’ve used different methods to counteract that (richer AF ratio, retarded valve timing, etc.). I’m optimistic about this piston tech and what it could do for diesels. It has already done that much, despite its infancy. I don’t know if Nickel-Boron would help with the soot (its used often in AR15 bolt-carriers as a way to prevent an awful amount of soot buildup), but that is a problem that would need to be fixed.
My hunch is that if it can burn fuel more efficiency, this might give room for higher-revving engines. This obviously needs to be reflected in design (such as bore and stroke, piston offset, etc,), but it would be a possibility. Maybe with lighter designs, but thats more of a material issue rather than design issue.
There is also the sad possibility of typical government becoming experts, and then they begin upping the regulation too fast. We’ve seen this with EVs and the “rush” to, despite the current market-trend and technology that is, and likely be available for the next 50+ years after, without literally breaking the bank on buyer’s wallet. Not to mention with China and their “cheap, economical, and well-built” EVs detonating on street corners. We’ll have to see where this goes, but I am hoping its for the better.
turbobrick240
maine
I got a look at the pistons used in those studies, and they have much different dimple size and arrangement than the speed of air pistons. That doesn't mean the SOA piston claims aren't mostly hot air, but those two studies aren't that useful to assess the SOA pistons.
BEWtheDEW
Montana
Exactly. The placement of those would matter a ton, since thats where the heat would direct itself. Arrangement definitely matters a ton, and will affect combustion pattern, and that woot could be less of an issue if its directed in a way to where it can escape with the exhaust more efficiently.
dieseldonato
Us
2001 jetta
Not new tech.... these guys have been around much longer then speed of air... and dimpled pistons, combustion chambers and intakes are not new. Circa 2005
Even honda experimented with "dimples" and oval pistons back in the 70's for a race bike engine application.
wonneber
Monroe, NY, USA
I’d definitely buy one, as long as it didn’t have lane assist, a TV, and in general think for itself.
My 2024 VW Atlas SEL has lane assist and does move me around on the highway a bit.
It goes crazy beeping if someone gets to close.
While I was working at Mercedes Benz corporate I got a demo drive of a hands off self drive car.
To say the least I was not comfortable riding in it. :unsure:
BEWtheDEW
Montana
For a diesel, its groundbreaking. And especially making them work reliably.
jmodge
Greenville, MI the winter water wonderland
More than I need, less than I want
I don’t like doors that lock by themselves or headlights that turn on without me flipping the switch. I’m pretty sure without trying it that I would not find that desirable. My idea of technology is starting a fire with a torch instead of matches
wonneber
Monroe, NY, USA
I like the headlights. :)
They auto dim for on coming traffic, They adjust a bit as I go around bends in the road, and shut off automatically after 30 seconds when I lock the car.
Maybe I'm getting spoiled with new technology? Yea yea dats the ticket. ;)
atc98002
Auburn WA
2014 Passat TDI SEL Premium (sold back), 2009 Jetta (sold back), 80 Rabbit diesel (long gone)
I like both of them, but I hated that the doors unlocked when I put the car in Park (my Taos). Fortunately Carista let me change that. Don't know why VW removed the user setting for that. I am going to have to upgrade my VCDS cable to with with the newer cars, but Carista was a fast, inexpensive way to make a few quick changes when I got the car.
lemoncurd
Eastern CT
2013 CJAA GTB2266
to the contrary, ive put nearly 100k miles on the comma ai openpilot self driving system largely problem free. best mod ive ever done to my car, and now i cant consider other cars which are not compatible with it lol
dieseldonato
Us
2001 jetta
No, it's not. It's been around for at least 15 years for industrial diesels. Dimpling in itself had been around much, much longer then that. The only company to date that's run any version of them in a production engine is Volvo, and that's yet to be seen how long they stick with them, and also not dimples.
BEWtheDEW
Montana
I am aware that it has been in performance applications. And huh, what kind of engine did they put that in? I would like to see that data on it. It would be interesting to see.
dieseldonato
Us
2001 jetta
Good luck getting any actual data from volvo.
jmodge
2017 is the year I quit working on them. With the exhaust emissions problems we had economy would have been impossible, and useless to measure. But......retirement solved all those issues, easy
