Cool piston tech
Figster
Pliny, WV
2002 TDI Golf
It isn't always a given that an add-on engine modification has an equal chance of showing up on the assembly line.
.....snip.....
As others have pointed out, vehicle mfg's are paying their own engineers to step around patent pendings, so why should they pay shade-tree inventors a percentage of their sales?
There is a WHOLE lotta "not invented here" syndrome alive and well in the auto industry. Achates power is a case in point. I've been following them for quite a while and they have plenty of data showing that their opposed piston diesel engine is more efficient than the standard 4 stroke diesel and can be made today to meet the future Ultra low nox and PM regs for California. The only somewhat commercial variant of it being developed (that I know about) is a combat engine for the Army.
turbobrick240
maine
It's an interesting idea, but the Speed of Air group seems very gimmicky/snake-oily. We'll see if it ever catches on.
Zak99b5
Albany NY
2003 Jetta TDI
Dude in that video is selling it as well. He tries to come off all skeptical, but then is Fully convinced they are the bees knees just by what the fat guy says, looking at and gathering zero data.
dieseldonato
Us
2001 jetta
That garbage has been around for many years. Mercer energy bit into it and had the pistons done on 2 G399 cat natural gas engines running generators. Didn't increase efficiency, or reduce any emissions. No reason to believe it does anything for a diesel either. Besides that if it did work every oe would be using it. Meeting emissions was one of the biggest packaging, cost intensive things they had to deal with. If simply putting a bunch of dimples in pistons would have yielded anything real reductions it would have been done.
jmodge
Greenville, MI the winter water wonderland
More than I need, less than I want
Killjoy
lemoncurd
PNW
2013 CJAA GTB2266
logical fallacy detected 🚨🚨
argumentum ad antiquitatem
idk... if you watched the video linked right above your comment, it seems theyre doing more than "putting a bunch of dimples in pistons"
the ring is different, it has a coating, CR is different, etc.
hell, if it was just putting dimples in your piston, everyone would be pouring ball bearings into the intake manifold right off the lot!
dieseldonato
Us
2001 jetta
The coating is new, there weren't any coating used on the g399 engines, however coating pistons isn't new, nor is coating the combustion chambers. Changing compression ratio also wasn't done, although I can see rhe basic benefit, lower combustion temps/ pressures leads to lower n0x emissions. One of the reasons cooled egr was introduced first. Displace some oxygen and get a colder combustion event. Not as efficient and won't make the same power vs an engine that doesn't have egr. Hence why egr is turned off at a certain throttle/load.
turbobrick240
maine
dieseldonato
Us
2001 jetta
Even if it was proven miracleware, what would be the ROI for rebuilding a perfectly good engine? 400,000 miles?
Depends on the engine, use, upkeep. 400k would be a pretty short life for an otr engine . Don't quite know how miles translates to hours in equipment, but on average somewhere between 8-10k hours would be a general idea for rebuild. (Application dependant.)
turbobrick240
maine
I don't think they'd ever recoup the cost. A set of 6 for a 5.9 Cummins is like $3500. You can get a set of Mahle coated pistons with the Total Seal rings for a third of that. The big mfrs aren't afraid to use unconventional piston designs if they can find an advantage. The Volvo wave top piston is a good example.
shoebear
Colorado Springs, CO
1998 Jetta, 2003 Jetta Wagon, 2005 New Beetle, 2013 Sportwagen
Whatever you think of the Speed of Air technology, they are about to release them for the 1.9 and 2.0 TDIs. Bookmarked to begin at the relevant comment, but the whole video is worth watching.
I'm convinced this is revolutionary tech and not snake oil -- but their pistons are expensive (at least for now). If I ever rebuild a TDI, I will look into the cost and decide then whether to use them.
Later in the video (start at 26:42), he says they just got EPA certification for the Duramax pistons as an emissions reductions device. They are pursuing certification for the rest of their applications as well. If you install their pistons in a Duramax, the expectation is that you can delete your DPF and DEF injection and still be legal. I think they still need to pass CARB certification before you can actually do that legally.
turbobrick240
maine
Haha. The only people who will ever be able to legally delete the emissions devices on road going diesels are the military and emergency response vehicles.
Mozambiquer
Versailles Missouri
No, you won't be able to "legally " delete that, as that is modifying the original emissions control devices.
But, if it is actually useful for that and causes the engine to meet or exceed the EPA requirements, it could possibly be certified for new vehicles, but I doubt the exact would do that without it having the dpf/scr systems.
shoebear
If they can prove to the EPA and CARB that - say, a 2015 Duramax - can meet the 2015 emission standards with a rebuild using their piston kit without the after treatments, I think they can be legally certified to run that way. That is what Speed of Air is working on, and I guess we'll see what happens. I'll be here cheering them on and rooting for their success.
Concerning use in new vehicles - I agree with turbodieseldyke - the EPA/CARB will take those gains as the new baseline and then create new, unreasonable demands with an impossible deadline to meet them. With those folks, the goal isn't clean air, it's forcing the end of ICE vehicles and cheap power generation. When 99.9% of Earth's population is dead and the rest are back in the stone age, they'll be happy.
turbobrick240
maine
Never gonna happen. I believe there could be some minor improvements to fuel efficiency, power, and emissions, but nowhere near the claims. It'll be the big new thing until it fizzles out.
Zak99b5
Albany NY
2003 Jetta TDI
They also add a gapless ring (wonder why the oil is cleaner?) and heat barrier coating to the top. Over on BITOG someone compared a set of Speed of Cash Leaving Your Wallet pistons to Mahle pistons, coated, plus gapless rings. The dimples made the fancy pistons cost 3X as much ($1200 vs $3700). I don’t remember what engine they were for, though.
dieseldonato
Us
2001 jetta
The fact of the matter remains, this isn't new "tech" and it's never once gained any traction beyond novelty. It is funny it seems to crop up every 10 years or so, then fades away into the sunset again.
Rob Mayercik
NJ, U.S.A.
Call me skeptical on convincing CARB to allow anything but what they want - I remember hearing the story about CARB forcing Honda to add catalytic converters to the original CVCCs even though the cars were meeting the emissions specs without them. Some day I gotta figure out if that was true or just urban legend, but frankly given the way CARB operates it's entirely believable.
In any event, if they do pull it off my hat's off to them...
CARB forced a bunch of crap on California-only Volkswagens in the '70s and '80s. And they could do it, because at that time, Volkswagen sold a significant chunk of the US sales in that state... more than any other. Some examples: 1974 Beetles, Ghias, and Things got a dual-preheated intake manifold, which meant the entire intake manifold, muffler, rear tin, was all specific to JUST those cars. 1974 Transporters with automatic transmissions got L-jet EFI. Manuals, and the rest of the country regardless of transmission got dual carbs for '74 (1975 all the Transporters got Bosch L-jet, as did the Beetles). My 1979 CA spec Transporter had electronic ignition (no points, like everyone else had), no EGR (curious... as the others DID), a completely different CA-only exhaust system with a specific catalyst that cooked the left cylinder head to death, and lambda feedback control (49 state Transporters did not have lambda control, and had a tiny little catalyst attached right ahead of the muffler).
Bunches of other CA-only stuff from that era... like the often made-fun-of 1980 CA-only Corvette, that was automatic-only, and 5.0L smogified V8 that managed a whole 105hp ... LMAO!
Don't see that anymore, because other states were allowed to adopt these CARB standards, and it became more difficult to make two versions. But there are still certain cars that were sold primarily [new] in CARB states that were not sold elsewhere. Like the Altima hybrid, or the RAV4-EV, etc.
adjat84th
Virginia Beach, VA
'01 Jetta TDI/'15 Golf TDI
What are the downsides to "gapless" setups, why don't OEMs use them if they have such great benefits?
Fisher Motor Works did a BMW with the fancy pistons, and (likely most importantly) gapless ring setup and saw 200C decrease in EGT across the rev range, substantial increase in torque (though they also saw an increase in compressor surge), and a claimed 20% increase in fuel economy.
I'd rather see the datalogs from their testing vs dyno charts, but they were very interesting results either way.
I've often wondered the same thing about the gapless rings... because I do not know of any OEM that uses them in their engines (but there may be some exotic exception?).
turbobrick240
maine
Too bad they aren't still doing the Mythbusters show. That would be a good one. Two brand new engines run side by side in dyno cells with full instrumentation.
Engine Masters, on MT Television... I think Freiburger and company would do it justice.
Of course, the problem with that is they have paid advertisers...
shoebear
If they could get an instant 20% mpg improvement & the rings only add a few dollars to the build price, why wouldn't they all use it? I could understand if it was still 1970 and the Big 3 were colluding with Big Oil to waste everyone's money, but with all the foreign competition onshore... probably not.
The 20% mileage improvement was for the whole package -- dimples, ceramic coating, and gapless rings, not just the rings.
