Its commonly known that when lowing the MK4 Golf/Jetta that once the lower control arms go past horizontal, the front end grip and overall handleling of the car decreases. This is because the front wheels go from negative camber to positive through the suspension travel. Here is a graph showing this travel, including lowering amount (from Vortex, I did not create).
Going back to the horizontal control arms, when lowing with the stock MK4 Golf/Jetta spindles, the control arms go over hoizontal and start to get negative angle(rise when going from the middle of the car to the spindle.
Lower you go, the more this comes into play. The stock static camber can still be adjusted to spec, but the camber curve once you load the suspension gets closer and closer to postive.
Appears the lower attachment point on the TT/R32 spindle is much lower than the Golf/Jetta, which would help level back out the control arms.
So, who has done the switch on a lowered MK4 Golf/Jetta? Before and after feel? My car handeled awesome last year, fat rear sway bar, sticky summer tires. Now that its lowered, it understeers more (tends to plow more). Seems this would be a bolt on option to get that front grip back.
Looks like one would need to swap wheel bearings, and get the right control arms with the nubs for the stock sway bar (or run no front which some recommend)? And there were some revisions to the bushing style wit the handeling recall on the TT.
More details here on the parts:
http://www.myturbodiesel.com/wiki/audi-tt-vw-golf-r32-spindle-and-lower-control-arm-conversion-mk4/
And no, this is not a discussion about raising the car back up to stock ride height. I already know that will help, and this is not a discussion about compromises with appearance, thats all already understood. Its how to make a slightly lowered MK4 Handle well again.
I like winding country roads, on ramps, and autocrossing, and also a nice appearing car.
Current ride height:
