convenience options/configuration
dillenger1
cleveland,ohio
2015 gsw tdi
can the automatic window be added with vcds?i think i read somewhere that only the passat got it factory.when i go into my settings .the only thing i have under the open close menu, is door locking
ProfBrown
So Cal
2015 GSW SE DSG
You can code it in if you have the the KESSY system. Does your car have push button start?
Cuzoe
Los Angeles
MK7 Golf S
What exactly are you trying to do? I have a Golf S, no KESSY, and have added windows up/down while holding lock/unlock on the FOB.
If you are talking about retro-fitting rain sensors to close your windows while you're away from the car that's another thing. Depending on what trim you have may require a higher model buddy control module. I think I may to have to upgrade mine to add front/rear fogs and ambient lighting.
You will require VCDS in any case. When I check my body control module there are options that VCDS says mine does not support. Alternatively you can use obdeleven for a lot of these things. I haven't used it personally but the interface is an Android app. Consensus seems to be VCDS is more powerful, but also more expensive. Obdeleven will let you read/clear codes and make coding changes.
As an example, I have power folding mirrors installed and have them set to fold/unfold with lock/unlock. The folding mirrors required upgraded door control modules. Still had to activate the convenience features and enable the menus in car settings to control them.
Sent from my ONEPLUS A6013 using Tapatalk
RIP TDI
Santa Barbara, CA
'15 GSW SE 6MT, '01 Golf 5MT, '97 Passat sedan, '96 Passat variant
I assume you also coded the mirrors to dip in reverse? If so, can you code them both to dip simultaneously?
Cuzoe
Los Angeles
MK7 Golf S
I do have the passenger mirror set to dip in reverse, for parallel parking. I don't remember if the option was there for the driver side or not. I'll try to check sometime this weekend.
RIP TDI
Santa Barbara, CA
To enable for Group 42 (Driver's mirror) its the same procedure as you did for Group 52. Once its set up, I'm just curious if you can only dip one side at a time using the select switch or whether there's a way to set it up for simultaneous dipping (sounds like a dance move!).
ProfBrown
So Cal
2015 GSW SE DSG
Yeah on my car with the mirror dip I have to leave the switch on the right side to keep the dip working. I doubt you could do both at the same time.
RIP TDI
Santa Barbara, CA
You can enable "Synchronized mirror adjustment" in the menu, but I assume that's for manual adjustment only, not automatic dipping with memory return to previous position when out of reverse.
RIP TDI
Santa Barbara, CA
Cuzoe, could you confirm that you have correct memory operation on your passenger side dip, i.e., that the mirror returns to its exact previous position when out of reverse?
ProfBrown
So Cal
2015 GSW SE DSG
I have this tweak done, and yes mine does return to the position I had it in last (2015 GSW SE). After backing into a spot it will only return once I have turned the engine off. Or if I start to drive away. It is not instant once you pull the car out of park.
RIP TDI
Santa Barbara, CA
I enabled passenger dip also on my SE but the return is a bit higher than the original position. I have read that the memory function only works correctly (i.e., returns to the exact original position) when the uprated door module is installed. I also enabled driver's dip and, consistent with what I've read, it does not dip or return with the standard door module.
Cuzoe
Los Angeles
MK7 Golf S
I can confirm that it returns to the same spot. And it did require the new modules. I believe the part numbers end in 592/593.
RIP TDI
Santa Barbara, CA
Cuzoe, a few more questions:
1. Does enabling "Synchronized mirror adjustment" to the menu screen allow double synchronized reverse dipping or, as its name implies, is it just for manual adjustment?
2. I know you installed power folding mirrors and the matching door modules at the same time, but do you have a sense of whether just replacing the modules alone would allow for "correct" dipping (i.e., exact position return)?
3. Is there a position memory feature (for two or more different driver profile settings) available in the coding when folding mirrors & modules are installed?
