I sat in my car in the cold reading for many hours, and the condensation from my breath collected on the windows, and ultimately began to drip down. This is what case the problem I think. As I sat, the rear hatchback lock began to repeatedly, sporadically lock and unlock on it's own. Later in the day the emergency blinkers came on on their own and I discovered the battery was drained. After jump-starting, I discovered that the steering wheel controls, windows, turn signal, cruise control, horn, windshield wipers, high beams, interior lights, air conditioning, remote key fob, and seat warmer controls were all inoperative, but otherwise the car drives fine.
I replaced the rear hatch actuator, but this did not fix the problem. A VCDS module scan shows that the Central Convenience (Comfort) and the Network modules aren't communicating (I posted the full logs below with some of the stranger error message bits). I checked the fuses beside the driver's door and under the hood and couldn't find any blown fuses. Maybe I should look again . . .
I called VW Parts, and for the 2012 Jetta Sportwagan, based on my VIN, there are 3 variations of the Convenience control module that would work:
5K0937087ADZ3A, 5K0937087TZ5Q, and 5K0937087tz83. The cheapest price I found was $420 from 1stVWparts.com had the cheapest price with no used options on eBay. Any suggestions for finding one of these used?
Where the heck are the Convenience and the Network Modules located?
Are there any relays that may be involved that I could check or are there any other fuses not in the owner's manual that I should check?(locations and pictures if possible!)?
Speaking of the owner's manual, it's not a very good resource, and Bentley doesn't seem to have a book for the 2012 Jetta Sportwagen, any suggestions for detailed technical information?
I found this VW site: https://erwin.vw.com that charges $35 a day for access.
Thanks so much for any and all help.
Below is the VCDS information from VagCom that Richard Middleton username: coolairvw on TDI club who runs www.kansascitytdi.com helped me pull from my Sportwagen:
Friday,12,February,2016,08:30:30:06946
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 14.10.1.1 (x64)
Data version: 20150130
VIN: License Plate:
Chassis Type: AJ (7N0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 2E 42 44 46 52 56 62 72 77
VIN:
01-Engine -- Status: OK 0000
09-Cent. Elect. -- Status: Cannot be reached 1100
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
1C-Position Sensing -- Status: Malfunction 0010
2E-Media Player 3 -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: Cannot be reached 1100
52-Door Elect, Pass. -- Status: Malfunction 0010
Address 01: Engine (CJA) Labels: 03L-906-022-CBE.clb
Part No SW: 03L 906 019 HG HW: 03L 907 309 AA
Component: R4 2,0L EDC G000AG 8178
Revision: 12H14--- Serial number:
Coding: 0050078
Shop #: WSC 00066 000 00000
VCID: 77FD827E06D666995FA-8022
No fault code found.
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 02E-927-770.lbl
Part No SW: 02E 300 057 P HW: 02E 927 770 AL
Component: GSG DSG AG6 512 3102
Revision: 05551213 Serial number: 00001204040400
Coding: 0000020
VCID: 26439F3A91FC2F1134C-8073
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BL HW: 1K0 907 379 BL
Component: ESP MK60EC1 H31 0152
Revision: 00H31001
Coding: 114B600C492200FC881306EB92220042B70000
VCID: 7DF19056E4EA4CC9056-8028
Address 08: Auto HVAC (J301) Labels: 3C8-907-336.clb
Part No SW: 7N0 907 426 AN HW: 7N0 907 426 AN
Component: AC Manuell H19 0404
Revision: 00001018
Coding: 0000001002
Shop #: WSC 00066 000 00119
ASAM Dataset: EV_ACManueBHBVW36X A01010
ROD: N/A
VCID: 000FE9A29B1821216E0-8055
No ASAM data for: "EV_ACManueBHBVW36X" (VW36 *)
Address 09: Cent. Elect.
Cannot be reached
Unable to communicate with address 09. Are you sure the doors are unlocked?
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 5K0 959 655 H HW: 5K0 959 655 H
Component: AirbagVW10G 013 0724
Serial number: 003GVRA1B9VA
Coding: 00003133
ASAM Dataset: EV_AirbaVW10SMEVW360 A01014
ROD: N/A
VCID: 3F8D2A5EA6669ED957A-806A
Subsystem 1 - Part No SW: 1KM 955 557 HW: 1KM 955 557
Component: S.Sens.Fahr.V H01 ----
Serial number: 3572MSME7904056DZZZ.
Subsystem 2 - Part No SW: 1KM 955 557 HW: 1KM 955 557
Component: S.Sens.Beif.V H01 ----
Serial number: 3582MSME6526216CZZZY
Component: S.Sens.Fahr.H --- ----
Serial number: 3511HSME3812642BZZZI
Component: S.Sens.Beif.H --- ----
Serial number: 3521HSME7B0D642BZZZ-
Component: F.Sens.Fahr --- ----
Serial number: 35527SME2B476B2BZZZU
Component: F.Sens.Beif --- ----
Serial number: 35627SME690D692BZZZX
No ASAM data for: "EV_AirbaVW10SMEVW360" (VW36)
3 Faults Found:
9439771 - ROD - Unknown Error Code
- 00 [137]
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 92784 km
Date: 2042.14.05
Time: 06:39:11
9445937 - ROD - Unknown Error Code
- 00 [137]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 245
Mileage: 92784 km
Date: 2042.14.05
Time: 06:39:19
9444629 - ROD - Unknown Error Code
- 00 [137]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 92784 km
Date: 2042.14.05
Time: 06:39:11
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 5K0 953 507 AH HW: 5K0 953 549 B
Component: Lenks.Modul 008 0080
Revision: -------- Serial number: 90440LC6000W6
Coding: 188A140000
Shop #: WSC 00066 000 00184
ASAM Dataset: EV_SMLSNGKUDS A05001
ROD: N/A
VCID: 76E38F7AC9DC1F9144C-8023
Subsystem 1 - Part No SW: 5K0 959 542 A HW: 5K0 959 542 A Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H09 0013
Serial number: 0188341
Coding: 820000
No ASAM data for: "EV_SMLSNGKUDS" (VW36 *)
3 Faults Found:
117012 - ROD - Unknown Error Code
- 00 [009]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 245
Mileage: 92784 km
Date: 2042.14.05
Time: 06:39:10
117028 - ROD - Unknown Error Code
- 00 [009]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 245
Mileage: 92784 km
Date: 2042.14.05
Time: 06:39:10
147464 - ROD - Unknown Error Code
- 00 [009]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 21
Reset counter: 252
Mileage: 92784 km
Date: 2042.14.05
Time: 06:39:10
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 5K0 920 972 C HW: 5K0 920 972 C
Component: KOMBI H03 0607
Serial number: 00000000000000
Coding: 270F01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04114
ROD: N/A
VCID: 306F79626B3871A1DE0-8065
No ASAM data for: "EV_Kombi_UDS_VDD_RM09" (VW36 *)
2 Faults Found:
12664832 - ROD - Unknown Error Code
- 00 [009]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 245
Mileage: 92784 km
Date: 2042.14.05
Time: 06:39:13
13631488 - ROD - Unknown Error Code
- 00 [009]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 21
Reset counter: 252
Mileage: 92784 km
Date: 2042.14.05
Time: 06:39:13
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 M HW: 1K0 907 951
Component: J533 Gateway H42 1623
Revision: H42 Serial number: 23051201270016
Coding: 352002
VCID: 3A7B5B4AB544BBF1604-806F
2 Faults Found:
00457 - Control Module for Network (J519)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 245
Mileage: 92784 km
Time Indication: 0
Date: 2042.14.05
Time: 06:39:15
01330 - Central Control Module for Central Convenience (J393)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 245
Mileage: 92784 km
Time Indication: 0
Date: 2042.14.05
Time: 06:39:15
Address 1C: Position Sensing
Cannot be reached
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H03 0607
Serial number:
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03009
ROD: N/A
VCID: 6ADBAB0A8D64CB71D04-803F
No ASAM data for: "EV_Immo_UDS_VDD_RM09" (VW36 *)
Address 2E: Media Player 3
Cannot be reached
Address 42: Door Elect, Driver (J386) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 561 959 701 HW: 3C0 959 793 B
Component: TUER-SG FT 002 0501
Revision: 13110009 Serial number: 0004703492
Coding: 0004B5
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_TSGFPQ35BRFVW46X A04001
ROD: N/A
VCID: 5BB5FECE523EA2F95B2-800E
Subsystem 1 - Part No SW: 3C0 959 703 C HW: 3C0 959 795 D Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 008 1509
Serial number: 00000006675204
Coding: 000490
No ASAM data for: "EV_TSGFPQ35BRFVW46X" (VW36)
2 Faults Found:
68098 - ROD - Unknown Error Code
- 00 [009]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 245
Mileage: 92784 km
Date: 2042.14.05
Time: 06:39:13
68100 - ROD - Unknown Error Code
- 00 [009]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 245
Mileage: 92784 km
Date: 2042.14.05
Time: 06:39:13
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K0 909 144 P
Component: EPS_ZFLS Kl. 70 3305
Revision: 00H22000
Shop #: WSC 02069 000 90108
VCID: 377D427E4656A6999FA-8062
Address 46: Central Conv.
Cannot be reached
Address 52: Door Elect, Pass. (J387) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 561 959 702 HW: 3C0 959 792 B
Component: TUER-SG BT 002 0501
Revision: 15110009 Serial number: 0004712908
Coding: 0004B4
ASAM Dataset: EV_TSGBPQ35BRFVW46X A04001
ROD: N/A
VCID: 5CB7FDD25730A5C1528-8009
Subsystem 1 - Part No SW: 3C0 959 704 C HW: 3C0 959 794 D Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 008 1509
Serial number: 00000006563150
Coding: 000490
No ASAM data for: "EV_TSGBPQ35BRFVW46X" (VW36)
2 Faults Found:
- 00 [009]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 245
Mileage: 92784 km
Date: 2042.14.05
Time: 06:39:12
- 00 [009]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 245
Mileage: 92784 km
Date: 2042.14.05
Time: 06:39:12
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 1K0 035 180 AE HW: 1K0 035 180 AE
Component: Radio Prem-8 H02 0016
Revision: -----16S Serial number: VWZ4Z7M3300101
Coding: 01000400040007
VCID: 63C5C62E624E9A39132-8036
1 Fault Found:
00849 - S-contact at Ignition/Starter Switch (D)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 245
Mileage: 92784 km
Time Indication: 0
Date: 2042.14.05
Time: 06:39:12
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 5K0 035 730 E HW: 5K0 035 730 E
Component: TELEFON H09 2902
Revision: 1B001001 Serial number: 00007662162354
Coding: 0A10040000010100
ASAM Dataset: EV_UHVNA A01719
ROD: N/A
VCID: 275D923E5EF636190FA-8072
No ASAM data for: "EV_UHVNA" (VW36 *)
End-------------------------(Elapsed Time: 03:33)--------------------------
VIN: License Plate:
VIN:
Coding: 0050078
Coding: 0000020
Revision: 00H31001
Revision: 00001018
Coding: 0000001002
ROD: N/A
Cannot be reached
Coding: 00003133
ROD: N/A
3 Faults Found:
- 00 [137]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 92784 km
Date: 2042.14.05
Time: 06:39:11
- 00 [137]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 245
Mileage: 92784 km
Date: 2042.14.05
Time: 06:39:19
- 00 [137]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 92784 km
Date: 2042.14.05
Time: 06:39:11
Coding: 188A140000
ROD: N/A
Coding: 820000
3 Faults Found:
- 00 [009]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 245
Mileage: 92784 km
Date: 2042.14.05
Time: 06:39:10
- 00 [009]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 245
Mileage: 92784 km
Date: 2042.14.05
Time: 06:39:10
- 00 [009]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 21
Reset counter: 252
Mileage: 92784 km
Date: 2042.14.05
Time: 06:39:10
Coding: 270F01
ROD: N/A
2 Faults Found:
- 00 [009]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 245
Mileage: 92784 km
Date: 2042.14.05
Time: 06:39:13
- 00 [009]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 21
Reset counter: 252
Mileage: 92784 km
Date: 2042.14.05
Time: 06:39:13
Coding: 352002
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 245
Mileage: 92784 km
Time Indication: 0
Date: 2042.14.05
Time: 06:39:15
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 245
Mileage: 92784 km
Time Indication: 0
Date: 2042.14.05
Time: 06:39:15
Cannot be reached
Serial number:
Coding: 000000
ROD: N/A
Cannot be reached
Coding: 0004B5
ROD: N/A
Coding: 000490
2 Faults Found:
- 00 [009]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 245
Mileage: 92784 km
Date: 2042.14.05
Time: 06:39:13
- 00 [009]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 245
Mileage: 92784 km
Date: 2042.14.05
Time: 06:39:13
Revision: 00H22000
Cannot be reached
Coding: 0004B4
ROD: N/A
Coding: 000490
2 Faults Found:
- 00 [009]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 245
Mileage: 92784 km
Date: 2042.14.05
Time: 06:39:12
- 00 [009]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 245
Mileage: 92784 km
Date: 2042.14.05
Time: 06:39:12
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 245
Mileage: 92784 km
Time Indication: 0
Date: 2042.14.05
Time: 06:39:12
ROD: N/A
