cuttyshark
I have a busted bushing on the front driver side. I bought a new control arm and went to install it. I thought I was prepared but hit a snag with the front bolt that faces the transmission. I tried the trick with using some leverage to push the transmission forward (i bought new bolts for the dogbone) and I could NOT get it to move enough forward for that long bolt. I think that trick must work better on the non-DSG transmission. I have a DSG. There is not enough room in front of the transmission to keep it from crushing the radiator, nor can I get enough leverage with the amount of space I have under the car. My only option is to drop the subframe!
What is the procedure?
I have secured NEW subframe bolt kit. I have the two new control arms (going to do both sides while I have it off). New dogbone bolts. I have the tools and breaker bars and sockets.
My main concern is after I get the 6 or so subframe bolts undone does it just drop down? I see there is a steering box up in there? Does that stay up or does it need support? Do I need to disconnect the steering or sway bar? I can't find any information or manual on how to do this.
Thank you!
Thank you!
