Considering a V10 - maybe...
da.hs
SK, Canada
2010 Golf, DSG, silver (from new). 2010 Audi Q7 (from 2016), 2004 Touareg V10 (from 2018)
2004, 260,000km (163,000 miles) : seller's comment "[FONT=&quot]The car has turbo leak problem and I will sell it as it is with a new turbo as a part for $11500".
This is $CAD not $US. Any opinions? V10 rare in Canada, probably a US import. I assume it's an engine pull to replace the turbo? I could probably do it eventually - have some shop space - would take a while. I certainly do not need another car but...
Opinions?
[/FONT]
Yeti35
SL, UT
2010 Touareg V6 TDI
You have to pull the motor to change the turbo and generally when it is out you also check a few other things while it is out. Change everything you can while it is out so as not to pull it again in a month or so to do it all again. I say great motor, but not something you want to work on or want to repair. Yes, you are getting it cheap, but still not a cheap car to repair. Walk away from it.
NoobyT
N/A
N/A
NEVER ever buy any Touareg with known faults - they can be a money pit and that V10 certainly will be - don't walk away, RUN.
Owain@malonetuning
Vancouver
335d, 05 jetta wagon, 84 jetta td
Very common to see turbo problems on these, any one that's this age without turbo problems, will have them sometime. Stepper motors are also a known failure point, that might be all it needs, or it could be a downpipe leak, never really know. I would rather buy one that requires these kinds of repairs at a lower price than have to do these repairs within a couple years anyway. Expect to drop the motor, 5K+ in parts, and an extensive rebuild. Install mildly upgraded turbos or a better oem replacement, delete pipes if the DPF is giving you problems, and then you'll have a slightly simplified vehicle.
The later GT2260 V6 touaregs make plenty of power and will about match a V10 with tuning (v10 being stock). I'd consider one of those since this rig will run you 20K+ easily.
da.hs
SK, Canada
I wasn't contemplating this vehicle as a low cost commuter, that's for sure...
A 2004 should have no DPF, surely?
Seller now says that it's non-running, intakes removed - so repairs underway and abandoned. This makes me much more wary.
