I think the point some are trying to make, gracefully or not, is that rebuilding an engine requires a bunch of information specific to that particular engine, *all* of which is in the service manual, and *much* of which the person doing his/her first TDI rebuild won't even know to ask on the interwebs, regardless of their years of experience with other engines.
In the case of this particular engine, stuff like:
- which bolts are re-usable and which aren't... there are many that aren't, for several different reasons
- all the various torque specs
- torque sequences
- clearances for bearings and rings
- how to determine the correct head gasket to order... it may not be the same as the one that was on there
If you have the manual you're told everything you need to know in the logical order you need to know it... if you only use the interwebs you're only asking the questions you know to ask... not always the same as the ones you should be asking.
It's not rocket science or secret stuff... just a lot of details that are specific to that particular engine design, and all nicely arranged and easily accessible in one thick service manual.
