Rob Mayercik
Vehicle in question: 2002 Jetta ALH, 01M automatic. Totally stock at 289,986 miles as of today.
A couple years ago I found out that my injectors were out of balance (this was about 60K ago), so had them rebuilt and the nozzles swapped out to Titan .205s, under the impression that this would be a good "mild upgrade" for an otherwise bone-stock car.
Well, not so much - I was "rolling coal" pretty much anytime the engine came off idle. I had the injectors dialed down a couple times and the injection pump "hammer modded" to pull my IQ down, but eventually the vendor swapped me out a different set with slightly smaller nozzles (I never got a definite answer, but it was supposedly somewhere between OEM manual trans nozzles and the .205s) to get rid of the smoking.
After all of that, the heavy smoking was gone, but the MPG never really recovered to what I have historically gotten (usually 42-45 with 75-25 HWY-City mix, got a couple 47s logged in my spreadsheet), and it's been a fight to even make 40MPG now under the same conditions (last two tanks were about 37). Just had the timing belt done at 280K, and at the same time the guy who did it found and installed a couple SW upgrades from VW into the ECU.
It starts very easily (even with the extreme cold NJ's getting) and doesn't smoke, but when cruising at light throttle on the highway I feel it running rough/uneven (to the point where it had me thinking the trans was popping in and out of gear). Put a little load on it and it settles down.
Had the guy who did the timing belt look at it, and he's of the opinion that the trans is fine, and it's either one or more injectors or the "advance" in the pump going. Since it starts so easy, he is leaning toward injectors, so the plan is for me to order up an all-new set, swing by his place for install (with the hours I'm keeping at work, this beats waiting 6 months to find time to DIY it), and then return my old ones for core.
Right now I'm leaning toward the MT injectors this time - I was going to do that originally, but then the vendor recommended the .205s and that didn't turn out too well.
If I understand correctly, the OEM nozzles on my ALH were .158s and the manual ones are .184. Does this sound right?
