pgoes
Hi all- I've been mostly lurking here for a couple years. I still have an 04 wagon, now with 156000 miles. It's been geared, had the tranny replaced, and had most of the usual faults that the Passat TDI is known for.
Now I can't smog & re-register the car because the computer reports that the EGR won't pass readiness. It was initially traced to a bad thermostat that didn't allow the temp to get high enough. But after replacing that the computer still will not reset, reporting that the EGR is not ready.
I have a good mechanic (AVS in Berkeley, who have done most major work); and he and I have both followed the published steps to reset readiness (warm up, idle, 2 minutes at 60 MPH/1800RPM, coast down, etc.). Still not ready. Since it is still at the shop I cannot quote the exact values or verbiage that the reports give. Its been in the shop going on 2 days now and he's at a loss-- is checking wiring, sensors, whatever may be connected.
Can anyone here in the community suggest a productive direction to investigate? or anyone had a similar problem?
