Normally each morning, before you touch anything, the red blinking light next to the drivers door pin will be blinking. The manual says if you leave your car locked for 30 days, the light will stop blinking so you don't use up your battery.
My guess is....maybe not only does the door alarm lite stop blinking, but to save battery juice the radio and trip OD stop being fed "maintain" voltage. And...maybe the sign of the "system" coming to life is - when the door is opened and closed - the car beeps to tell you it has turned those items "back on".
So....maybe the piece (chip?) that counts down the 30 days, is losing count intermittently and shutting down.
Or....if the 30 days is really an estimate, maybe the "time" is based on the battery voltage decreasing a certain amount (estimated to be a 30 day period) or to a certain low level.
Therefore, maybe the above posters are correct. It is your battery....faking the car to think it's been sitting longer.
Just a guess.....
