compu_85
Gadget Guy
Time for some spring cleaning! Prices are less shipping.
$Free! 8mm 1.6 ECOdiesel injection pump. Car had 380,000 miles on the odometer when this was removed due to leaks. Throttle lever plate on the top was also removed. The car did run though.
$Free! Mk2 diesel Sanden AC compressor. Has been sitting open. Never got around to trying it out. Moves smoothly though.
$50 New Mk2 AC receiver / dryer, expansion valve, and o ring kit with R134a fittings.
$5 New Mk2 door handle gasket set. I'll include 1 new door hinge pin!
$20 New late Mk2 front brake pads. For vented rotors.
$25 99.5 / Mk3 shifter parts (number). These are the primary pieces which wear out and make for a sloppy shifter. Parts are in great condition, were only in use for ~15,000 miles.
$40 99.5 transmission shift tower. Unknown miles, I got this when I found mine was worn. Worked fine. Includes working reverse light switch.
$25 99.5 shifter box and cables. Came out around 280,000 miles. In good shape with little play.
$15 Mk4 single din CD player. Hooks between the changer and head unit. Had some trouble with some disks, perhaps a head cleaning would help?
If you don't like my prices make me an offer No, I won't pay you to take the injection pump
Pictures to follow. I'll post more stuff as I find it
-Jason
-Jason
