JSWTDI09
I'm no expert on these things, but it looks like the CP4.2 only has a single fuel metering valve (just like the 4.1). Are you certain that the issue is in pumping volume and not metering volume? I assume that the fuel metering valves are not identical in these two pumps, but I'm just thinking about where the most significant "choke point" might be. Doubling pistons will only be helpful if they can actually pump twice the fuel (or at least significantly more fuel).
Also, does the CP4.2 have the same double cam driving the pistons up and down? Two pistons moving at half the frequency will not necessarily pump more fuel (unless they are significantly larger pistons).
Again, I'm no expert. I'm just sharing my musings.
Have Fun!
Don
Have Fun!
Don
