Common TDI CEL causes?
spongebob
Mesa, AZ
Not anymore.
What are some common causes of CEL on TDIs?
30 days ago I had an intermittent CEL taken care of, replaced a faulty coolant temp sensor and the light went away... Until today, I have another CEL. :mad:
Only thing different lately is I'm down to the last 2-3 gallons of the first tank of biodiesel I've run in four years. I know BD can send fuel tank sediment buildup from D2 use into the fuel filter. Would a fuel filter issue cause a CEL, or is this likely the glow plug bridge or something else?
mrGutWrench
Carrboro, NC
'03 Jetta Wagon, 5-speed, 563K Miles (July '23)
oilhammer said:
No, 90% of YOUR POSTS are false positives... :rolleyes:
__. I consider a diagnostic system that's only indicating a problem with the diagnostic system to be giving false positives.
meganuke
TDIClub Contributor, Vendor
VA/CT
2010 Ford Fusion Hybrid
Wow...just wow. Let us know if you find any oil reserves while your head is buried in the sand.
burpod
teh stallionz!!1
cape cod, ma
__. How do you propose the glow plug harness to be monitored by ODB? :confused:
Hehe, Gutwrench talks like a fortune cookie. Makes you say "huh?" without really thinking about it. :p
A DTC indicating a fault in the glow plug circuit is very simple. We have tried to explain this to you, and even in light of the fact that I fix about 3 such DTCs a week successfully you STILL seem to think YOUR CAR is the only TDI in all of North America that has some mysterious German demons giving your car and only your car false DTCs (whatever those are) and that nobody anywhere can fix it. What a load of BS. You really need to sell your cars, both of them, so we don't have to listen to you dig yourself further and further into a hole week after week after week.
meganuke
VA/CT
If your doctor's stethoscope is broken, do you trust him to tell you your heart is fine? Or do you replace the stethoscope?
BadMonKey
Colorado
2013 Focus ST
95% of the codes from my car are related to the GP's or the MAFS. Only about 5% of those actually required a new part.
Fahrfuwerfuelen
Puget Sound
Jetta, 2005 (A4), Platinum Gray
Just my 2 cents. I've had 4-5 CELs and everytime they came out to be P0672- #2 cyl glow plug circuit. The VW techs (under warranty) are stumped and tend to agree with me that it's probably the harness, although they can't replace it until they can establish the harness is at fault.
I got one such CEL (P0672) and replaced my fuel filter cause I felt the response was not right. Right after I replaced the filter, the CEL disappeared. Go figure that one?
rdkern
Humboldt Co CA
Did you check to see if the code is still there? Sometimes the CEL is thrown by a code coming a couple of times, then goes away if the code isn't thrown again in 20 starts (another figure made up on the spot- but some number of starts). However, the code may still be there. Get it scanned and let us know.
CELs go away, generally codes must be cleared.
spongebob
Mesa, AZ
Not anymore.
NarfBLAST said:
Spongebob, fix the problem with your radio that is preventing you from using your diagnostic port and get your car scanned!
No idea how to fix the way the radio is hooked up. I'm not tech savvy.
BadMonKey
Colorado
2013 Focus ST
velociT said:
And 72% of statistics are made up on the spot...
Including ^ that one.
I actually keep digital records of all the work done to any of my cars including diagnostic scans.
Thanks for chiming in with nothing to add but a line from an old Comcast commercial.
spongebob
Mesa, AZ
Not anymore.
Got the car scanned. Code was #2 glow plug but glow plugs tested good.
So I guess it's the 4-wire glow plug harness. Here in Phoenix, glow plugs are just to provide ECL's I guess? ;)
So I guess it's no impact on drivability, I'll just get it replaced when I can.
Bob_Fout
Oil Wanker
Indiana
If it lists glowplug #2 as bad, trying test glowplug #3. On some model years, the glowplugs are number backwards.
Glow plugs are used for emissions for post-startup, and are always on for a certain period of time after engine startup.
midntdi
New London
2015 Golf SE 6SP
how bout a CEL that comes on when my auto tranny is in drive (but in reverse, park, nuetral there is none)
Edit: Just went to advancedauto parts and got scanned P0674 yay glow plugs
