I swapped my bottom end for another stock bottom end for now. To get a little more life out of the current bottom end I went back to 764 nozzles. I had R520's in there previously when I broke a piston ring, which then broke the piston. Always run it hard, along with a handfull of track days, and oh 420,000 miles on her. The other mods I do have right now are RC5+, a colt stage 2, ported head, double valve spings, 11mm, 17/22 turbo, 28PSI, 3 bar map, 764's, PD150 intake, 3" exhaust, bigger IC piping, VR6 MAF and Airbox.
What I'm getting at is, with the smaller nozzles I'm not smoking at all, the car looks like a gasser, I need bigger nozzles to match my air flow. So with fairly heavy mods the increased air flow apparently is working. Now appears to be starved for fuel. I do need to run some logs to see where I'm at.
