JustLuckey
I have been doing searches for cold weather options (heaters and ways to prevent the cold from affecting my 2 vehicles: 2006.5 Jetta TDI & 2005 Dodge Ram 2500 Cummins). I already use a couple of these options, but decided to share some of my research with everyone. The purpose is to put this information into a single thread, as I had to read through dozens of threads on this site and others to come up with this info. Maybe someone can better format this and turn it into a 'sticky', if useful.
Some of these options are geared towards biodiesel blend users, but most are for those that live in cold weather regions and concerned about warming/fuel gelling issues with normal diesel.
FAQ: Does my VW TDI have a engine (block or coolant) heater?
EDIT: Upon futher searching, this is not a cut and dry question/answer. It appears that a true 'block heater' is/was available for older TDIs (90s models, possibly into early 2000s). But the current heaters that are put on certain Canadian models (dependong on trim) are recirculating coolant heaters (like or same as frost heater). U.S. doesn't have this option from the factory or dealer.
Company: Frostheater
Type: Coolant heater
Purpose: Heat & circulate coolant
Power: 110VAC
Site: www.frostheater.com
Cost: $120-140 +ship (depending on model)
Notes: Very common in TDI community, many references on tdiclub.com forums
Company: Diesel Injection Service
Type: In-line Fuel Heater
Purpose: Heats fuel before it reaches fuel filter
Power: 12VDC (150 Watt)
Site: www.disnet.com (item not listed on site, must call)
Cost: $52 + ship
Notes: I have been using this in my 2005 Dodge 2500 Cummins for almost a year while running B50 thru 100% D2 and have had a very good experience. DisNet uses them on all of their VW vehicles in their fleet. My friend has been using it for 2 winters and is very happy with it.
Company: Nomad / Parker / Racor
Type: In-line fuel heater
Power: 12 or 24 VDC (300 watt)
Site: www.parker.com (go to PRODUCTS | HEATERS)
Cost: Unsure
Notes: I found this online, but have not researched it. At 300 watt, it is double the power output of the DisNet option, which works fine for my Dodge Cummins, I think it's overkill for my VW in PA. Maybe in colder locations, this would be a good option.
Company: Fryer to Fuel
Power: DC
Site: www.fryer-to-fuel.com
Cost: $160-165 (depending on size)
Notes: I have not researched these much, as (with above) it's designed for WVO heating and is probably overkill for little to no biodiesel blends (what I'm using it for), plus it's more than twice the cost of the DisNet option.
In-line fuel heaters and other heaters can also be found at www.arctic-fox.com, but I know nothing about them, they could very well be a great product.
Type: Heater Wrap for Fuel Filter Housing
Purpose: For wrapping around fuel filter housing to prevent gelling at the fuel filter.
Cost: $60-90 (depending on size)
Power: 12VDC
Notes: I have the small version and it works well on my Jetta TDI.
Company: Ultraheat
Type: Fuel Tank Heater Pad
Purpose: Warming fuel in tank
Site: http://www.ultraheat.com/rv_products.html
Power: 120VAC, 13.5VDC, or Both/dual
Cost: $91-130 (depending on size)
Notes: My friend (who runs B100 year round in his Ram 2500 Cummins in North NJ) has one and has positive results (combined with fuel filter wrap, and inline fuel heater)
Zerostart (http://www.zerostart.com/coldStart/diesel_cold_Start_technology.asp) also has some cold weather heating options. I don't have any experience with them.
Kat also makes heaters (magnetic & silicone pads running on AC, I believe). Google "Kat Heaters" for more info.
Front end covers or blankets could also be considered a item for this thread, as they do help insulate the engine compartment. If you search, you will probably find vendors that sell them custom made, but many people make them out of cardboard or use/cut pipe insulation and insert into the grill.
Since some of you also have other (non-VW) diesels...
For my Dodge Ram 2500, I will be purchasing the cold weather kit (Radiator cover, 2 electric heater blankets, and wiring harness for the OEM block heater). Cost $160-200 depending on vendor.
The cover is sold seperately, as well. Cost: ~$120
Obviously, there's other heating products and options out there. Maybe this is a good starting post for others to provide some info on other products.
I'll try to check back on this thread periodically & correct any info (OEM block heater?) and add any good info in responses, to keep the info consolidated.
Regards,
JustLuckey
Power: 110VAC
Cost: $52 + ship
Cost: Unsure
Power: DC
Power: 12VDC
Company: Ultraheat
Regards,
JustLuckey
