Fastbird
Same issue I've been dealing with for going on my third winter now. Cold start only, very pronounced diesel nailing, and around 1750 RPM stumbling and hesitating, until engine starts warming up.
Car is NOT hard setting any codes. VCDS will show a pending code for "torque difference" on Cylinder 2 (I believe, been a while since I've looked at it). Symptoms are pointing to a failing injector like many other people have experienced.
HOWEVER......the local VW dealership says their computer shows no pending codes and refuses to even try to diagnose further. They test drive and say it's "normal" or check the oil and say it's slightly overfull and causing the problem.
So my question is......what is the threshold for getting that Torque Difference code to hard set? I've driven the car and had the stumbling so bad the car wouldn't accelerate anymore and no code ever hard set, no check engine light.
