Cold hard start
armstrongtrucks
Butler,PA
2015 PASSAT SEL TDI
2015 Passat. First cold start of the day taking a lot of cranking. Once it starts the rest of the day it fires up normally. 97000 miles and all filters changed at 90,000. No sign of any diesel leaks as it sets in the garage.
Any suggestions?
thanks in advance
bustNfuel
Raleigh, NC
13 Passat SEL TDI DSG
I'm at 108k and mine's starting to have difficulty starting. Extended cranking for about 3-5 seconds, then stumbles and runs. Runs fine afterwards.
Then last week I had a CEL with two codes, and after further investigation found a lot of sludge in the bottom of the intercooler. I wonder if yours is about to have the same problem.
My post here, with pics:
pedroYUL
MI, USA
2004 wagon BEW; 2015 Passat CVCA; 2015 GSW CRUA
Your 2015 Passat is closer to a 2015 Golf than anything else (quoted thread). I will save you the pain to read the many pages there, there are multiple factors to consider:
1. Battery. Make sure it is good, if still the originally fitted, then consider a new one.
2. Variable valve timing system: This is one of the first things considered in the thread. You can open the very end of the valve, make sure oil is nice and liquid there with no crud, no chunks in those passages.
3. Crank position sensor: Other threads have pointed to cars with flakey sensors and no codes set by the ECU at all. Changing the sensor is easy and cheap if you can DIY, just something to take out of the equation if you keep experiencing long cranks and perhaps some hesitation when driving.
4. Priming: Make absolutely sure your fuel system is well primed, the transfer pump (inside the tank) can be commanded to run by VCDS with both the engine off, and also running; try it both ways a few times. Also, some people (including me) have changed the pump for a new one, not crazy money if you DIY, but not peanuts.
5. Not discussed in the thread, but I would also recommend to have a quick look at the screen and inside the hole of where the pressure regulator lives on top of the HPFP. Just undo the two T20 screws and wiggle the regulator out. If there are metal flakes anywhere in there, you HPFP is seriously compromised, to the point of absolutely grounding the car until the pump is changed.
Tom in PT
Twilight Zone, WA State
I started that intercooler buildup thread in post 2 and FWIW I never had a hard to start situation arise, ever, in my '13, even with intercooler buildup.
In addition to pedroYUL's excellent suggestions, I would also mention make sure the glow plugs are cycling and give it a 5 seconds before you turn key to start to make sure they have done their business. If that does not change things, proceed along his suggestions. There must be NO air in the fuel system.
