ApproachMedium
So my engine when started up makes some kind of noise, almost like it did when my injector harness failed on the #1. It does this once the engine runs for a minute and idles down. If i tap the gas gently it stops making the noise. It sounds like its coming from the bottom end of the motor. I first noticed this months ago after the injector harness was repaired and had it running up on my lift. I figured it was from the fuel and it being so cold out. Now it seems to do it when the engine is cold. Once it warms up it goes away but then the engine idle vibration is felt in the cabin more pronounced than id think. This is less when its warmer out, much worse when colder. Im thinking that part is the dogbone mount.
Could the mount be causing the noise i am hearing? Injectors? the number 1 injector was replaced. I do also need a timing belt replacement, i have 126k and no history on the car so its possible its worn a bit? Just trying not to blow this car up.
