yahmon
- Joined
- Dec 27, 2012
- Location
- canada
- TDI
- 04 passat tdi 6spd stage2 webasto TC3 , 04 passatW8 6 spd, 10 Jetta TDI 6spd stage 1
Replaced the condenser and radiator fan on my 2010 tdi jetta and when i go to start it to charge the AC all hell breaks lose, it started first but wouldn't run right, just like someone turn the power on and off. Then it stalled and wouldn't start at all. Performed fuel pump test and all seems in order. Decided to hook up vcds and noticed during cranking that the fuel pressure stays down but once and a while spikes up and all of a sudden start. managed to keep it running for a bit and got these readings and wonder if others have run into this before. Also lost the fan inside too in the process. It sure indicates a power supply or ground problem I think.
3 Faults Found:
001648 - Glow Plug Module 1; Glow Plug Circuit
P0670 - 000 - Electrical Malfunction - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 182700 km
Time Indication: 0
Date: 2046.14.14
Time: 10:28:28
Freeze Frame:
RPM: 184 /min
Speed: 0.0 km/h
Voltage: 12.69 V
Temperature: 17.1°C
Bin. Bits: 00010000
Time: 1.98 s
Temperature: 16.2°C
008852 - Fuel Pressure Regulator Valve (N276)
P2294 - 000 - Open Circuit - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 182700 km
Time Indication: 0
Freeze Frame:
RPM: 253 /min
Speed: 0.0 km/h
Voltage: 11.78 V
Pressure: 8.0 bar
Inj. Quantity: 24.2 mg/str
Lambda: 46.6 %
Lambda: 45.8 %
000401 - Fuel Pressure Sensor (G247)
P0191 - 000 - Implausible Signal - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100000
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 182700 km
Time Indication: 0
Date: 2046.14.22
Time: 00:49:11
Freeze Frame:
RPM: 1771 /min
Speed: 0.0 km/h
Lambda: 4.7 %
Pressure: 864.0 bar
Pressure: 728.0 bar
Pressure: 0.0 bar
Temperature: 18.0°C
3 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 182700 km
Time Indication: 0
Date: 2046.14.14
Time: 10:28:28
Freeze Frame:
RPM: 184 /min
Speed: 0.0 km/h
Voltage: 12.69 V
Temperature: 17.1°C
Bin. Bits: 00010000
Time: 1.98 s
Temperature: 16.2°C
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 182700 km
Time Indication: 0
Freeze Frame:
RPM: 253 /min
Speed: 0.0 km/h
Voltage: 11.78 V
Pressure: 8.0 bar
Lambda: 46.6 %
Lambda: 45.8 %
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 182700 km
Time Indication: 0
Date: 2046.14.22
Time: 00:49:11
Freeze Frame:
RPM: 1771 /min
Speed: 0.0 km/h
Lambda: 4.7 %
Pressure: 864.0 bar
Pressure: 728.0 bar
Pressure: 0.0 bar
Temperature: 18.0°C
