codes after replacing ac condenser and radiator fan
yahmon
canada
04 passat tdi 6spd stage2 webasto TC3 , 04 passatW8 6 spd, 10 Jetta TDI 6spd stage 1
Replaced the condenser and radiator fan on my 2010 tdi jetta and when i go to start it to charge the AC all hell breaks lose, it started first but wouldn't run right, just like someone turn the power on and off. Then it stalled and wouldn't start at all. Performed fuel pump test and all seems in order. Decided to hook up vcds and noticed during cranking that the fuel pressure stays down but once and a while spikes up and all of a sudden start. managed to keep it running for a bit and got these readings and wonder if others have run into this before. Also lost the fan inside too in the process. It sure indicates a power supply or ground problem I think.
3 Faults Found:
001648 - Glow Plug Module 1; Glow Plug Circuit
P0670 - 000 - Electrical Malfunction - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 182700 km
Time Indication: 0
Date: 2046.14.14
Time: 10:28:28
Freeze Frame:
RPM: 184 /min
Speed: 0.0 km/h
Voltage: 12.69 V
Temperature: 17.1°C
Bin. Bits: 00010000
Time: 1.98 s
Temperature: 16.2°C
008852 - Fuel Pressure Regulator Valve (N276)
P2294 - 000 - Open Circuit - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 182700 km
Time Indication: 0
Freeze Frame:
RPM: 253 /min
Speed: 0.0 km/h
Voltage: 11.78 V
Pressure: 8.0 bar
Inj. Quantity: 24.2 mg/str
Lambda: 46.6 %
Lambda: 45.8 %
000401 - Fuel Pressure Sensor (G247)
P0191 - 000 - Implausible Signal - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100000
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 182700 km
Time Indication: 0
Date: 2046.14.22
Time: 00:49:11
Freeze Frame:
RPM: 1771 /min
Speed: 0.0 km/h
Lambda: 4.7 %
Pressure: 864.0 bar
Pressure: 728.0 bar
Pressure: 0.0 bar
Temperature: 18.0°C
yahmon
canada
What was the nature of having to replace the A/C condenser and fan(s?)? Was the car crashed?
nope, AC wasn't working rock damage on condenser, fins all smashed in and fan had little piece of plastic missing, just decided to fix all at once
Mach1
Spicewood, Tx.
05.5 Jetta 5 spd, 06 Jetta DE DSG, 04 F250 6L, 2000 F250 7.3L
Was there other work performed at the time? I cant think of anything that would cause that..
Was the intake hose removed..FF replaced? ETC.
yahmon
canada
Nope nothing was touched, this thing literally died on the hoist.
Mach1
Spicewood, Tx.
Wow..sounds like fuel system, have you had the HP pump replaced since new?
yahmon
canada
Why would you think it's the hp pump, it seems electrical to me, even the fan quit.
