Clutch Upgrade
Taggs
Jetta, 2001, Blue
I know this is beeting a dead horse, but I need specifics about the clutch upgrade. I am aware that the clutch I need is the VR6. I am unsure about the flywheel. I need know what other VW the flywheel that I need comes from. Thanks, Dave
BlakGolf
MTL canada
2000 mk4 golf
the flywheel can only come from a g60, its the only way to use a vr clutch on vw 4cylinder engines. theres a couple companys that make the lightweight ones for cheaper then the oem g60 flywheel
im still hunting for a used oem one
Taggs
Jetta, 2001, Blue
Thanks for the info.Do you have any of the companies names? Thanks, Dave
mwalters
SE Michigan - Have VCDS
Jetta TDI 2013 Tornado Red
You could also keep your original dual-mass flywheel and go with a SPEC clutch. I have a stage 1 SPEC and it works great, even with my mods.
Taggs
Jetta, 2001, Blue
Where would I locate the info for a SPEC clutch?
