Clutch & transmission installed - here are 2 tips
shoebear
Colorado Springs, CO
1998 Jetta, 2003 Jetta Wagon, 2005 New Beetle, 2013 Sportwagen
Wonder of wonders, everything works!
Tip 1: Use a block and tackle for lowering and lifting the trans, and also for aligning the engine for the dogbone mount installation. See below for photos.
Tip 2: Ski bibs are very helpful when working outside in subfreezing weather. Dressed just in insulated pants, sweatshirt, and medium weight winter jacket in 20°F weather yesterday, I got pretty thoroughly chilled. Today in 5-15°F temps, I added ski bibs and a stocking cap, and I stayed relatively warm.
Block & tackle photos:
Hooked up and ready to start lifting.
Coming up! Note that I started the lift with the transmission bracket attached, but I removed it to get past the power steering line.
Did the job solo, so I tied loops in the rope at stopping places in the pull to hold the transmission while I went below to adjust the trans position.
For most of the lifting, I hooked to a small shackle attached to the place the transmission bracket brace bar attaches to the transmission. This lifted the differential, which was helpful getting past the subframe. Once I had the transmission almost in place, I hooked on the slave cylinder hole for final alignment.
PakProtector
AnnArbor, MI
Mk.4's and the Cummins
Nicely done, and thanks for the photos. I am contemplating similar, but using instead a cherry picker for the lifting and something like a tie strap to join between it and the gearbox..
Douglas
gforce1108
Newburgh, NY
04 Jetta GLS BEW, 14 Audi A7 V6 TDI, 13 Porsche Cayenne V6 TDI
I just use a ratchet strap on the engine support bar - works well enough to lift it in place. I use the bolt hole right by where you have the hook and it's near perfectly balanced. For removal it just about pops out onto the ground. Old pic before I had my shop - had to freeze in my parents garage!
