ymz
- Joined
- May 12, 2003
- Location
- Between Toronto & Montreal
- TDI
- 2003 Jetta TDI Wagon, 2003 Jetta TDI Wagon
I had a hydraulic fluid leak at point "A" in the photo... it was leaking even with the clutch pedal up...
The end-piece "B" rotates a bit on the hose end, but the leak is not from the "O" ring (which would come out on the other - internal side of the housing). I got a bag of seals 1K0 798 741, and various online sources say I should be also replacing the larger, thicker seal - but... where would it go? There's no such seal present now in the slave cylinder... as well, the leak appears to be internal to that end-piece. Is the hose beyond rescue or is there a way to stop it from leaking there?
Yuri
Yuri
