Clutch Release Lever Failure - Clutch/Shifting Problems Fixed
sullyTDI
North Augusta, SC
2014 Jetta TDI
Wanted to throw this out there for information.
My 98 Beetle TDI Started having problems going into gear almost over night. (Original Clutch)
Was like hard to go into first, and fifth where the worst others where hard to, reverse would grind.
I knew from reading the forum posts, that the clutch wasn't releasing properly.
So I check the fluid and it was to the minimum mark. So, that ment air in the clutch system, I bled, and bled and bled. No change.
Anyway, took it to my trusted mechanic, he thought the same thing I did. He bled and bled. Nothing.
So we decided it was something in the clutch broke. He pulled it and low and behold, the clutch release lever,
steel had failed, cracked and bent 1 1/2" out, severly limiting clutch release.
Here is a photo borrowed from IDParts.com showing where it had cracked and failed. As this one is shown, cracked and the end bent downward.
Edit: This must have been going on a while, we replaced the clutch and lever, an now shifts better than it ever has..
jagster936
Texas
2002 Beetle TDI Manual
Similar Situation
I had grinding issues in 02 ALH and pulled the tranny. Turns out the clutch release lever had hole worn in where it pivots and the pivot bolt was well worn. 473k miles cannot blame her :)
PeterV
TDIClub Enthusiast, HO5G Doyen & Zen Master
So, NH.
2000 Jetta 5 sp.
You are not alone. This is an issue careful inspection during replacement is needed. In your case well it is life. Just think of how many times the clutch is used over 19 years. Dang it my old leg is starting to hurt.....
sisyphus
Appleton, Maine
99.5, '01 A4 Jetta sedans, 5 sp box, Hamman mod, Joey mod, Bilsteins, 2.00" lift
Same here, on an '01 with a little over 230k.
jagster936
Texas
I don't know why people say rated life is 500k on these cars. With highway miles I bet it's more like 700k. This was original clutch and turbo too!
