pkhoury
That guy with the goats
Earlier today, while trying to shift into 5th, the car wouldn't let me get into 5th and heard some grinding (like synchros), so I backed off. Then found, I couldn't get into ANY gears. I coasted to a stop where it was safe. Before that, the clutch pedal felt like it got stuck on something (as if a rock were behind it or something). Now, the clutch pedal hesitates a fair bit before it goes down to the floor. I can't get the car out of 5th, either (on a tow dolly).
If I start the car with the clutch pressed to the floor, it naturally stalls and doesn't even turn over, because it's acting as if the clutch is fully engaged. When I did get it to start (while parked to the side of the road), there was a light chattering. Pressing the clutch pedal slightly made it silent. Trying to press it further started making grinding noises. I was initially planning to change fluids in my tractor today, but tackle both that and the car. That said, should I either try to bleed the slave cylinder, or remove it entirely first, so I can at least get back to neutral to get the car off the tow dolly?
Thankfully, I have a spare clutch/flywheel/pressure plate here, but I wasn't planning on doing a clutch job in triple digit heat (or 90 degrees around 11pm). Any thoughts?
