borachris
SMF and helix clutch problems with GTB2260VK
I've just fitted a GTB2260VK to my 130 ASZ, I've got a Helix SMF and clutch kit.
Before I even had a map for the 2260(just had a standard ARL 150 file on) I had a bit of a play with a mate in his Golf from a standing start, What I thought was wheelspin was actually the clutch slipping.
I had the revs at about 2200 let the clutch out and set away, the revs shot up to about 4500-5000 and stayed there all the way into 4th gear were I realised what was happening and backed off, at that point the clutch finally bit.
Question is, what should I replace? Flywheel shoud be fine, but should I change the plate and the disc or just the disc?
I need to order the parts and do the job all in one hit so I can't really take it to bits and inspect them first if you know what I mean.
Also does anyone know if the southbend clutches will mate up to my Helix flywheel?
