baldessariclan
I'm having a perplexing issue with the clutch pedal in my 2014 TDI Sportwagen - can't figure out what's going on or what the problem might be. Here are the symptoms:
- Couple days ago, went to drive car (after had been sitting a couple days since last drive) and found that the clutch pedal was resting all the way in, up against the floor / firewall (held there by the over-center assist spring).
- Pulled clutch pedal out by hand, and found could easily move pedal in and out, with no pressure or resistance felt (other than from the over-center assist spring). The assist spring holds the pedal in either the fully extended or fully pushed-in position when I let go.
- Car was working fine before that, clutch pedal operated and felt completely normal - no degradation in performance, soft pedal, or anything like that which I detected or can recall.
- Looking up at the master cylinder piston rod area and clutch pedal assembly (from the footwell), everything looks dry - am not seeing any fluid leakage there.
- Looked down at master cylinder assembly from the engine compartment side, everything looks dry there - no fluid or leaks that I can see.
- Looking at the ground underneath the car, there is no fluid dripping or pooling under there.
- Checked the brake fluid reservoir, and it's completely full - seems to be no fluid loss there either.
So I'm at a complete loss as to explain this behavior right now. I mean, moving the pedal in and out by hand, I feel absolutely no resistance or pressure buildup in the clutch system (other than from the pedal assist spring). It sort of feels almost like there's no fluid in the master cylinder at all, and/or it's completely dry. But once again the brake fluid reservoir is still completely full, and I'm not seeing leaks anywhere - ??
So anybody ever have similar issues, and/or ideas about what might be going on???
