I've got a 2005 Jetta TDI with the BEW engine coupled to a five speed transmission. I bought the car with 152k on it and to my knowledge it has the original clutch in it. It now has 230k on it and in the last few thousand miles there has been an intermittent issue where the clutch does not completely disengage when the clutch pedal is pressed. Most of the time when I first crank up the clutch will fully disengage and it shifts as smooth as you'd expect it to. But after a few miles it starts to have trouble shifting. If I come to a stop light and it is in first the clutch is still grabbing and the car is still trying to go forward so I'll put it in neutral and when the light turns green I have a hard time getting it back into gear. I tried bleeding it at first and that did not seem to fix it so I put a new slave cylinder on it today hoping that would fix it but it still seems to have the issue. After installing the new slave cylinder I pressure bled the system, pumping fluid into the slave until I continued to get fluid out of the brake fluid reservoir. I did it this way so I'd be pushing the air up and out instead of trying to get the air to go down and out. Since it only seems to do it after the car has started to warm up I was assuming it was temperature related and was thinking there was an imperfection in the piston of the slave cylinder allowing it to bypass fluid. I don't want to keep throwing parts at it hoping I get the right thing. Has anyone else had this kind of issue before? If so what was the fix? Thanks in advance. Let me know if I left out any information that would be useful!
