15austin
My clutch does not seem to be disengaging all the way. It grinds slightly going in every gear like the clutch in not all the way down. Does the hydrolic clutch have an adjustment? Any ideas what i can do?
Brake fluid as in the dot4 clutch fluid? I have not changed it. I did check it its full. Had the car 1 1/2 weeks now so no idea if it has or ever been changed.How is your brake fluid level?
Did you have it changed recently?
Nope. You can do that without even pulling the gearbox out.If i pull the trans it would be a good time for 681 5th gear swap to i guess
Wow. Did not know that. Is there a write up about it?Nope. You can do that without even pulling the gearbox out.
Is there a rebuild kit I can buy or just some o-rings?? Also I have. 755 stock 5th gear, right?You probably have a leaky master or slave cylinder. Not sure if the VW has a pilot bearing in the end of the crank, but I had a truck where the pilot bearing seized on the end of the trans shaft so the clutch could never disengage. Given the miles I'd say the hydraulics on the clutch need a rebuild. O-rings don't last forever. Then again, if that's the original clutch you may due for a new one. They don't last forever either.
Try pennzoil synchromesh before you condemn the trans ....it works wonders on tired brassI had this problem on my 99.5 Jetta.
Kept bleeding the clutch hydraulic circuit which seemed to marginally improve it for a short while.
Also changed both the master and slave cylinders.
Eventually, after driving it like this for two years, it was correctly diagnosed as a broken Dual Mass Flywheel which I had changed.
But now all that shifting with a clutch that could not completely disengage the transmission from the engine has ruined my syncro's in first gear...
