TPW
- Joined
- Dec 2, 2017
- Location
- Minnesota
- TDI
- 2003 A6 Avant BHW 6 speed manual, 2003 Golf ALH 506k miles
I just installed a new G60/VR6 clutch an SMF in a 2006 Jetta. I bled all the air out of the hydraulic system with MYTVAC and the usual pumping and bleeding. The problem is that the clutch doesn't disengage when I push it in. There is some pedal resistance but it seems a little light. There is no fluid leaking from the master or slave cylinder. I can put a short rod against the clutch release lever and it does move but I'm not able to move it far enough this way to get it to release either. Should I replace the master, slave, both or would you suspect something else?
