79TA7.6
- Joined
- May 8, 2006
- TDI
- 2003 TDI Jetta, 2002 TDI Golf, 2005 TDI Golf
I am finally going to be putting in a new DC stage 2 clutch this week. I have been reading up on the install and it does not seem that bad. I have done one before, but it was 15 years ago on an S-10 pick-up. Anyway, I have three tunes to choose while breaking in the clutch, stock, Malone 1.5, and Malone 3. Which would be best? I have been running the 1.5 as my clutch would not hold the 3.
Also, I am going to be changing the timing belt at the same time. It shouldn't matter which one I do first should it? The new flywheel has timing marks on it so that will not be an issue. Could I drop the trans, then do the timing belt? I would be able to move the engine around easier, maybe even push it back a little to make my life easier, but I am not sure if I should or not. I have changed three belts in the past, but it has been about 4 years since my last one. My memory is not all that clear on whether it would be easier or not.
