Drivbiwire
Zehntes Jahr der Veteran
- Joined
- Oct 13, 1998
- Location
- Boise, Idaho
- TDI
- 2013 Passat TDI, Newmar Ventana 8.3L ISC 3945, 2016 E250 BT, 2000 Jetta TDI
A few DMF/G60 Clutch suppliers:
-G60 Flywheel upgrades:
www.dieselgeek.com
www.vwparts.com
-DMF Clutch Upgrades:
www.specclutch.com
This is the installation procedure of the G60 flywheel and the SACHS VR6 clutch. These same steps will work on a DMF Clutch including the LUK so everything below should apply with the exception of various torque settings as always check the Bentley manual for all torque specifications that pertain to your car and clutch manufacturer. When installing the G60 Flywheel use the torque specs for the A3 Crank to flywheel bolts.
These are the special tools you need to have for this job:
From left to right:
VW 3067 (Mantra) Flywheel holding tool
VW 3190A Clutch disk centering tool
8mm Triple Square
12mm Triple Square
www.zelenda.com
I also strongly suggest:
Engine support from Harbor Freight
Transmission jack from Harbor Freight
The flywheel holding tool holds the flywheel while you torque down the crank bolts, trust me its worth EVERY penny when you torque then add the additional turn to these things. The Disk centering tool makes the installation of the tranny much easier, if the disk is not centered your gonna have hell to pay trying to support a tranny and wondering why it won't engage the clutch splines...not fun when your man handling 100#'s of transmission.
The 4mm triple square is to remove the drive shaft bolts. The 12mm is to remove the OEM crank bolts ONLY if you are installing a G60, if your sticking with the OEM flywheel and upgrading to the higher clamp force pressure plate and disk then it's not needed.
Press the new flywheel over the crank centering hub. This is a tight fit so you may want to have a rubber mallet for this step. Note that the bolts are machined off set so there is only one possible hole pattern.
Lightened Flywheel installation notes:
Verify that there is in fact a TDC mark stamped in your flywheel. If not you will have to use a chisel and stamp one yourself. As you may already realize this will take a bit of careful planning and EXACT alignment of the new mark, any error setting a TDC mark WILL RESULT IN A CATASTROPHIC FAILURE WHEN INSTALLING A NEW TIMING BELT.
Install the crank holding tool. This tool counters the torque that you are going to apply when torqueing the crank bolts down. Considering the torque setting this tool is invaluable!!! Tip: After torqueing each bolt mark it with a marker or crayon so that you do not apply an additional 90 degrees of rotation to the bolts.
Verify that all the bolts have been torqued. And make sure that the flywheel rotates and does not rub on anything.
Apply some grease to the splines as well as the centering tool. If the tool is new you may have to file the sharp edges OF THE TOOL down slightly or just gently tap it through the clutch plate with a hammer, I SAID GENTLY!!! Once you use it a few times it will slide right through.
Push the tool all the way through the clutch plate then….
Insert the tool with the clutch plate on it into the centering hole in the crankshaft.
Once the tool is inserted into the centering hole slide the clutch all the way flush and into the flywheel.
The holes for the pressure plate are machined offset like the crank bolts so there is only one way to install it. The pressure plate will just barely engage the alignment pins so once the pins are aligned with the holes…
Insert the NEW bolts that came with your clutch kit. Finger tight is all we are looking for. Once they are all started give each bolt 3 turns then go to the next one until all the bolts are good and snug AND the pressure plate has pulled itself flush up against the flywheel. Once all the bolts are tight NOW you can torque them down per the specification for you clutch manufacturer OR VW.
Once the pressure plate is torqued down, remove your clutch centering tool. This may take a bit of force due to the new splines and tight fit of the clutch disk. Also the disk may settle in one direction or the other when torqueing the pressure plate down. Bobble and wriggle it loose then remove it.
Inspect the centering hole now apply the rest of the spline grease that came with your clutch to them. A little goes a long way so DO NOT over apply this stuff, the last thing you want is melting grease getting on your new disc if it gets hot…
The manual says to use a holding pin…Well here is my trick. Get one of the bolts that holds the shift linkage to the transmission housing. These are blue bolts that are 8mmx32mm long. Insert one of these bolts into the hole just above the TDC cap. Once its started…
Push the throw out bearing arm in and turn the bolt the rest of the way in. This prevents the throw out bearing from getting out of alignment when jostling the tranny back into position.
Hope that helps the Clutch installers out there…
DB
www.dieselgeek.com
www.vwparts.com
www.specclutch.com
From left to right:
8mm Triple Square
12mm Triple Square
www.zelenda.com
DB
