I usually use a 1/2 inch socket extention bar to centralise the plate before I tighten the pressure plate bolts. Never had a problem so far on at least 12 clutches that I can remember. I just put the bolts in until they're gripping the plate and no more and then just kind of move the bar gently to nudge the plate. As long as you're gentle it should be fine. Don't force it if it's tight though cause you really don't want to damage the splines. Just slacken the bolts a little then try again. Hope that helps.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
