clunking sound in steering rack
glacier9
so. Wis.
03 Jetta TDI wagon, (2) '96 Passat TDI wagons, (2) '84 GTI's; '86 RX7; 2010 Ram 2500 Cummins Turbo Diesel
2003 Jetta TDI Sportwagen: When I turn the steering wheel left or right, I hear one (and sometimes two) clunks. This only happens when the car is stationary, with engine running. I don't hear it when the car is moving (forward or reverse) while turning in either direction. Otherwise, the steering feels great, and everything else appears to be solid as well. Any suggestions as to what could be the cause?
Gvr
Romania
'01 Alh Golf Mk4 Wagon
Order some shock mounts aswell since you'll be in there..
glacier9
so. Wis.
The struts and bearings are fairly new (Bilstein HD) and they are quiet, even with a stethoscope pressed on them. There seems to be a bit of play in the steering wheel with engine off and steering wheel unlocked, and there should be no play. We can definitely hear the noise coming from the steering rack area. I'm going to bring it to my mechanic who does the things that I can't do, or don't feel confident doing. Actually, I should say "we" won't do--My buddy who got me hooked on TDI's knows way more than I do.
I've got to get this right because I taking it to Autobahn Country Club on June 5 for a track day. The first time I went there, I drove up to the Tech Barn and it was deserted. Someone told me that if you're not confident in your own car, you shouldn't be there. That place is a BLAST: 3.56 mile 19 turn road course. It sure beats a country club built around golfing.
I'd post a couple (boastful) pictures if I knew how...
burpod
teh stallionz!!1
cape cod, ma
it might be the u-joint bolt has loosened. i had the problem once in a car.. it had somehow come loose, causing play in the steering wheel along with some clunkiness
03TDICommuter
So. Cal
01' NB, 5spd
I had that happen on a Grand Marquis that I rented from Hertz in MN. The clamp wasn't tight on the splines on the steering shaft. Took it back and got another car.
ts888
PNW US
03 ALH
I'd start with checking the fasteners that mount the rack. Not a common thing to be loose, but it happens. Also check the antiroll (sway) bar, they are a common source of clunks and other noises. Sometimes helps to go at it with a pry bar, as the weight of the car is holding things so just grabbing and shaking may be insufficient to reveal a fault.
Beyond that, could be inner or outer tie rod ends, could be lower ball joints. I wouldn't suspect control arm bushings, those usually make noise when braking or accelerating, and you might feel shimmy or see cupping in the tire tread.
We did have a BEW wagon a while back that had a broken spring, and it would make a popping noise when turned in one direction.
JB05
Il.USA
Golf,2005,anthracite blue
Check for broken front springs. Had this happen on my Golf.
glacier9
so. Wis.
Will be taking a very close look at it on Thursday. Thanks for the suggestions so far
glacier9
so. Wis.
Snug up rack & pinion bolts, that was it. We pried on the sub-frame/rack area while the car was on the lift and the attachment seemed fine...should have put a wrench on the bolts. Ready for Autobahn CC on Monday!
burpod
teh stallionz!!1
cape cod, ma
nice :) easy peasy
