I feel a clunk in the front end while getting on the brakes. It's more pronounced when you give them a quick jab. I'm thinking strut mounts or the bearings?
Have a friend look at your tire and wheel from beside the car when tapping the brakes. If the lower control arms are gone then you will see it move back a few inches.
Then I would jack it up and check for any play in the wheel back/forth and side/side. Then take off the wheel and check to make sure caliper bolts are tight.
