joshwa
I have a 100PD Passat 1.9 TDI '01 engine and performance seems lacking. I've tested it (disconnected the Bosch MAF sensor to find I get much better performance) and feel that the MAF is at fault - has anyone had any luck cleaning the MAF? I've tried carb cleaner spray through the pipe after the air filter, but this didn't seem to do anything... I'm tempted to take the MAF sensor out and clean it outside the car to see if this helps?
Thanks in advance,
Josh
Thanks in advance,
Josh
