TDIinVT
I have been having power issues at 2k+ RPMs. I then discovered algae in the sending unit. I then added Bioguard to the fuel and changed to fuel filter. I got no improvement so I ran a can of Diesel Purge thruough it.
That's when I decided to clean the injector nossels. They were real bad looking! Cleaning went well even without a garage to work in. I ran out of daylight and had to finish the next day. I covered all "open" parts with rags for the night. I put on new injector washers and torqued everything to spec. After double checking that all is right I preceeded to start my car.
I saw some fuel seep out of #1 injector and fuel seemed to be circulating.
I suspect that I didn't get the block clean enough to allow the injectors to seal properly.? It was getting dark fast at that point.
Any suggestion? Should I take it apart and flush everything out?
