Can anyone say what a plugged up EGR cooler does to performance/operation?
Well, the dirtier it is, the less efficient the EGR cooler becomes. Coolant warm-up times would suffer, and if left long enough, EGR flow would suffer. In my case, my EGR valve and intake were really plugged up...and by association, so was my EGR cooler. I didn't count the exact amount of tubes, but I'd say it was 30% blocked. So, a 3rd of the tubes were completely plugged, and the remaining 70% of the tubes were probably 50% blocked. It took me quite a while to get them all punched out.
Does it matter much in the grand scheme of things? Maybe not. For me, it was one of those things that I couldn't leave alone. I didn't want to re-install a shiny clean intake and shiny clean EGR valve with a dirty/plugged EGR cooler, and I had it all apart anyway.
Before engaging in intake cleaning I'd done some research and I really didn't see actual reported instances of such plugging. Lots of references to checking for it (no pictures?).
Well, it could very well be that my plugged up EGR cooler was a unique case. It could also be that many times, people do not check it...you have to remove the outlet flex line from the cooler to see the internal tubes. Although mine was quite plugged, my car wasn't throwing any codes for "EGR - Insufficient Flow".
So, to answer your question...does it affect performance/operation? I don't know. For the few of us that are running stock cars with the EGR systems still intact, it's probably worth a look. Judging by the lack of reports of problems, I'd have to say that it probably doesn't matter
Going by how dirty mine was, I'd like to think it worked better once it was cleaned. Then again, my car feels like it works better after a wash and interior vacuum
