I have a 2013 VW Passat 2.0 TDI. The car is throwing a P0101. The intake is not clogged. There is no leaks in the intake system. I did a smoke test. The MAF desired is pretty close to the actual. No change in ohms wiggling the wires. Any ideas? The code reads “performance/range” or “short/intermittent”. It switches verbiage every time it’s cleared. Any advice is appreciated! Thank you!
