RacingArcher
I purchased a 2013 Passat TDI a few months ago from a private seller with 158,000mi. The car is in amazing condition and seems to run fine, just took it on a 1200mi trip and my fuel economy was 38mi/gal, which isnt great but not bad. My issue is, it goes through oil like nothing else, 1qt/500mi or tank of fuel. At this rate I almost don't see a need to do an oil change. When I purchased the vehicle I changed the oil and filter using Mobil 1 esp 0w-30. While changing the oil I found a leak at the crank pulley so I replaced both the cam and crank front seals and now not a drop has leaked since. I have inspected the intercooler hose for oil and found nothing substantial other than a film. I think this thing is burning the oil almost as fast as I can put it in but with the DPF you would never know it because it never makes it to the exhaust tip. I am thinking that carbon build up on the oil rings may be causing this issue and was wondering if anyone has dug deeper into this motor for this reason and what did they find. My car is out of dieselgate warranty, probably the reason the previous owner sold the vehicle. I have done extensive reading and have found numerous owners with oil consumption but have yet to find a solution to the issue. I plan to do a compression check and leakdown test but I am not in any hurry because the car runs so good. Can carbon buildup be removed using spray chemicals in the intake like is recommended for direct injected gasoline engines, I did this on my 2013 F150 ecoboost and it seemed to work great, not sure if it would be safe on a high compression diesel though with DPF.
