N Nathan_og Veteran Member Joined Jun 3, 2021 Location Ontario TDI 2002 vw jetta 1.9 alh 5 spd Jan 24, 2023 #1 Does anyone know how to remove the chrome door strip on the drivers door? I have rust bubbles forming at the end of the strip and want to remove it to repair the rust underneath. Thanks
Scubanero Veteran Member Joined May 30, 2007 Location Calgary AB TDI 2005 Passat Wagon Jan 25, 2023 #2 It is held on with adhesive. A plastic scraper or similar should get it off for you and you can clean the strip and replace the adhesive to reinstall.
afarfalla Veteran Member Joined Nov 6, 2006 Location sugar land tx TDI 05 Passat sedan and 05 wagen Jan 26, 2023 #3 run fishing line down it
N Nathan_og Veteran Member Joined Jun 3, 2021 Location Ontario TDI 2002 vw jetta 1.9 alh 5 spd Jan 26, 2023 #4 Thanks for the advice! will do.
