Check your radiator/condenser fan operation NOW
ericas_beetle
austin
2000 New Beetle
Thanks You, I'll check. Ithought it was snowing in the car, but it was the dried out foam.
That sucks. It's time to decide how much you really like this car. It will cost thousands to hire someone to fix it, and about 25 hours to DIY. The entire dash has to come out, right up to the bulkhead in order to remove the HVAC box for servicing. If you decide to be brave and try it, go ahead and replace the heater core at the same time because it will surely be leaking very soon. The blend door foam problem is a major design flaw with these cars, right up there with leaking sunroof drains. I'm surprised they weren't sued over it.
para55a
Bridgeport WV
2002 ALH Sedan ; 2014 TDI Sportwagen
OK, at lunch I went out to the car. Turned on ignition, and
[/QUOTE
I went out at lunch and turned the car on but didnt start the engine. As earlier, the fan went on high, then cycled to low, then to high (you get the idea). Got out and removed the 30 amp fuse on top of the battery (looking down at the 3 fuses, it was the one on the left) and the fan shut off. Ah, i thought, this must be something, but what I done know other than the fuse is doing its job and passing along the power so does this mean I should look to the Fan Control Module as the next step?
para55a
Bridgeport WV
Excellent! and I do appreciate your most valuable advise. Checking on the condition of teh fuses and will report back
I truned the car on, removed the 30 amp fuse on top of the battery (one on the left) and the fan turned off. SHould I remove the battery and check power at teh FCM?
ericas_beetle
austin
2000 New Beetle
Don't make the mistake I made. Download the troubleshooting document in the very first post on page one of this thread. It will describe the order of operations, and there may be more than one problem. I had a bad fan but also had a bad fuse box.
By turned on, I assume you mean switched on but not started? That should be all that is needed to get the fans started on slow speed. Fast speed doesn't start until the car is getting hot. Verify your compressor clutch operation visually. I'm not an expert in the FCM. I think mine is still original. There is at least one video about it on youtube which might give you some hints. It doesn't seem like the worst job swapping it, but the general advice is to not install an off brand one and the genuine ones are like 250 bucks. So you wouldn't want to swap it for no reason.
If you saw the fans running on slow, then your problem might well not be electrical. Don't underestimate how big of a problem the blend door foam is. There are like 3 doors in the box and they're perforated like Swiss cheese, I assume so pressure doesn't create wind noise. The only thing that prevents them from leaking like crazy is the foam coating glued over them. Once enough blows off, then the temp becomes uncontrollable. I had no heat or AC, just a warm blend of the two.
JETaah
mi 48836
Those things usually lasted as long as they were responsible for them. Like a headliner, I guess.
J_dude
SK Canada
2003 1.9l “Jedi”
You don’t have to take the dash and HVAC box out to fix the blend door foam issue...
ericas_beetle
austin
2000 New Beetle
At this time I would not go through all of the dash removal, and miss the chance to replace the heater core also. Guaranteed it's about to give up. I lost mine a couple years ago. It's not a ton more work to get it out of the car, allowing for a proper box renovation, especially if it's a split box.
aster
Fairfax, Virginia
2004 Jetta Sedan GLS TDI
I will be the latest one to say thanks for this post! Went out and did the check. No fans and No AC. Changed out the fuse box on the battery (remembering to swap out the one 150 fuse for the 110 that came with the "supposed" OE replacement. That went great. Good first real project on the engine. Fuses in the side panel look good.
Now going to see if this is a leak by recharging the system with R134a to see if there is a leak. I noticed the filler valve has no cap...
Anyhow, thanks for this post and the commentary!
Gothmolly
Providence, RI
2002 Golf
I'm impressed by your persistence, on a 20 y.o. car I just live with the lumps.
apple4ever
Coatesville, PA
2002 Jetta TDI, 5sp manual, 310K miles
I had a similar problem that I had my mechanic replace the fuse box for me and that fix my AC problem as well (he also topped off the refrigerant that was low but still enough). Car is 23 years old and still has amazing AC - especially after replacing the fans at a meet with DanG about 10 years ago already!
Gothmolly
Providence, RI
2002 Golf
I think its my fans too. Surprising that they last this long I suppose.
SilverGhost
Back in So Flo - St Lucie
Just sat through an ASE training on how the new proposed rules and effective rules are going to work.
Big take aways - they are trying to phase out R134a supplies, but it will still take a while for prices to go up R12 territory.
EPA had new recycling rules that effectively would ban every machine in repair facilities - the purity requirements of Freon going into a car was not met by the current machines that recover, filter, recharge systems. Industry advocates have challenged this rule so it is not in effect, yet.
EPA already has rules that, in effect, ban small disposable Freon canisters (think parts store 1lb can). But again industry partners are challenging EPA on how to implement the rule. The problem is disposable cans are not pulled to vacuum to remove all Freon so waste of 50g per can. EPA wanted all cans returned to recover remaining Freon and recycle the cans. But how do you make sure all (or high %) of cans are returned? Also the machines to recover, store, and transporting of empties and Freon cost more than money than can be reasonably recovered.
There was also clarified that AC service for ANY compensation is regulated as a business and requires 609 license (this includes leaving a case of beer in the trunk for mechanic/buddy)
Making it harder to self repair and not run afoul of regulations....
Jason
Genesis
Sevier County TN
'03 Jetta Wagon
There is a point where hoisting the Black Flag is the appropriate response to government actions.
I'm not sure where that line is, and government always does these things incrementally thinking "well, they put up with that so we can do this" but at some point people simply have to push back -- or go broke.
J_dude
SK Canada
2003 1.9l “Jedi”
Yeah it's a common tactic where they clamp down with more rules and then when there is pushback they loosen up just a bit, but still not all the way.
That way the people think, "Well it's not as bad as it could have been..." but it's actually still worse than it was.
BobnOH
not-a-mechanic
central Ohio
New Beetle 2003 manual
Cluttering up a great thread with this conspiracy garbage.
SilverGhost simply conveyed some valuable information.............
aster
Fairfax, Virginia
So - after checking the vacuum pressure and realizing there was nothing left of the R134 in there (after it being charged up a couple weeks ago), it is time for leak inspection via the dye. Noticed a lot of corrosion by the rear tube. Guessing this is where the problem is located. Going to have the team at the HS take a look. Hopefully, this will be an easy fix. Going to go back and look for information on that fix.
Thanks everyone!
SilverGhost
Yeah, it makes our jobs harder as a repair facility and everyone who does their own repairs its getting tricky to stay out of trouble. And ignorance of the rules doesn't make the fine any less.
Oh, and not a new thing but it is being enforced more - have to vacuum check system and NOT charge a leaking system until leak is fixed. So, no, we cannot just top it off for the summer or until next pay cheque. R1234yf machines are setup this way to prevent charging leaking systems. Have to connect a nitrogen bottle (or some other method) and use soapy water or listening device to find leaks. Dye doesn't work as well anymore - manufacturers redesigned compressors to keep more oil internal and stop it from going thru system to meet certain rules/criteria, which also means most dye just collects in compressor.
Jason - ASE/VW Master and 609 holder
Nuje
Island near Vancouver
Not a conspiracy, it's a valid manipulation tactic 😂
See also: Shifting the Overton window ;)
Time to stock up on cans of R134a then.
It's getting tough to find on the shelf; I don't think it's available at all in Canada anymore, and my most frequent US stops (WA, OR, CA) have it banned; only by heading up through the corner of Idaho am I able to snag any.
Which brings up the question: What *can* be purchased in cans here (and there) is R12a - which is *NOT* R12; all of the R12a cans say it's "compatible" with R134a system; but can it be added to a R134a system? Or does the R134a system have to flushed and cleaned and then re-add the PAG oil and R12a?
SilverGhost
Quick search;
RED TEK 12a, a proprietary blended, highly efficient Hydrocarbon refrigerant, is designed as a direct replacement and retrofit refrigerant option for replacing R134a and R12 substitutes in automotive air conditioning and refrigeration systems.
MULTICOOL 12a is a surrogate fluid with a reduced global warming potential (GWP) for HFC-134a (R134a), R12 and 1234yf. It can be injected into all air conditioning systems operating with these gases such as automobiles, cold rooms ... etc
Oh, and this answers your question;
What happens if you mix r12a and R134a?
Incompatibility: R12 and R134a have different chemical compositions and properties. R12 is a chlorofluorocarbon (CFC) refrigerant, while R134a is a hydrofluorocarbon (HFC) refrigerant. Mixing these two refrigerants can lead to chemical reactions and damage to the system components.Sep 15, 2019
And this gem;
That's required by law. In most cases, mixing different types of refrigerants is illegal. Mechanically, adding R-12a to an R-134a system won't harm anything.
R-12a is a hydrocarbon-based refrigerant. It's mostly propane & butane, so highly flammable. It's also heavier than air so if it leaks it'll settle in the engine bay rather than dissipating into the atmosphere.
So it will function but will probably chemically react and do damage or other weird things over time. Bonus points if you do flush it out, because now its also highly flammable and most shops won't want to be anywhere near it. You had better get it perfectly leak free or any random spark in or near your car could make for fireworks. And any shop will be very angry if you don't tell them because their $3-8K machine will be screwed.
I guess my real question is this - why do you need to be topping off your AC so often?
Jason
LGA45
Missouri, US
MkIV Golf ALH
Haha... yeah... you may not notice, unless the first time you run the AC in a parking lot, the fan goes off the rails and turns into a smoke show... whoops... unplugged fan and no AC below 30mph for me. I gotta fix that... 🤦‍♂️
BBB129
Scottsdale, AZ
2005 Passat Wagon BHW 2004 Jetta 5 spd BEW - 99.5 jetta 5 speed - 1982 Mercedes 300D Manual 4 spd
So, oddly after I start the car and run ac, both fans with shot down within a minute, then threw ac compressor will kick off. However they will stay running if car is not running just on Acc. I don’t understand, car is not up to temp even right now. Any advice?
I noticed that one of my fans was making noise (which I ignored and waited till it stopped altogether) now I replaced and not sure why comp (or fans) doesn’t stay on while idling. My gauges are an hour away.
gmenounos
Watertown, MA, USA
'99.5 Golf GLS, '01 Jetta GLX Wagon (TDI conversion), Non-TDI: '23 Tesla Model 3 AWD
FYI: It's not that difficult nor expensive to get a 609 certification: https://ww2.epatest.com/epa-609-mvac/
