seaglf
Yeah I downloaded that file tbanksRead here: There is a test for both high and low speed fan operation, so figuring out which you've got is easy.
http://pics.tdiclub.com/data/516/A4_Coolant_Fan_testing_Rev_7.pdf
How are you sending power to each fan?So if I bypass power on the thermoswitch, I get nothing for the slow speed and for highspeed, only one fan runs.
I am working on my sons 2001 Golf GTI 1.8T. I have read and printed out Dan's trouble shooting guide. I am stumped and need more help.
Symptom:
With ignition on and a/c selected with fan control in low, i do not have any radiator fan or compressor clutch.
Items Checked:
Fuses 5, 16, 25, & green fuses on top of battery.
Compressor clutch, applied 12 volts to green/black wire on 10 pin connector at FCM. Applied ground to brown/black wire on FCM. A/C Clutch engages.
Monitored blue/red wire on 10 pin connector (FCM) for 12 volts when A/C Switch is on. Power follows switch position.
Checked Ambient temperature switch at FCM 10 pin connector, bl/ro to gn/bl 700 ohms. Logged into the ECM and it is showing approximately correct temp (86 degrees).
Checked high pressure switch connector (by expansion valve) for 12 volts, checked white wire and have 2.3 volts present with system turned on.
Applied a short across the radiator thermal switch, I get both low and high fan speeds depending on on contacts shorted.
Operated engine at 3,000 to see if compressor clutch engaged, it did not.
System has static pressure of 110 on both low and high sides.
At this point I believe I might have a bad FCM module, your help would be very much appreciated.
David L. Jones
Just a couple things that caught my attention.I am working on my sons 2001 Golf GTI 1.8T. I have read and printed out Dan's trouble shooting guide. I am stumped and need more help.
Symptom:
Items Checked:
On this car ('01 GTI) the temperature in ECM is NOT the ambient temperature switch. Also, notice it is call a "switch", not a sensor.
4 wire switch or 3 wire sensor?
Don't remember the exact cut off RPM, but repair manual usually asks for 1200-2000 RPM during tests. That may have been too high and actually shut AC off.
David L. Jones
That sounds nuts, where did you get those?...................................After trying five high pressure sending units, the sixth one fixed the problem.............................
0L so guess that means it's the clutch?What's the resistance across the clutch coil? If it's open you just found the problem.
Uh, yep. It should read something like 4ish ohms.0L so guess that means it's the clutch?
It's quite likely the fan itself is dead. The one that usually dies is, as you're seeing, the driver-side one. It's also quite-frequent for it to die only on low speed (that is, the resistor that drops the speed burns out, but the motor itself is still functional, so it will run on high -- at least for a while.)When doing the initial fan test (ignition on, AC button pressed), what's the cause of one fan (small) turning, but the other not?
Also, no cold air blowing (even with engine running). But, figuring out the bad fan first.![]()
Only possible snag is that when trying to remove the nut holding the clutch in place, the compressor shaft may break (given the age of the car)... in that case, you'll be replacing the entire compressor, which will entail the "expert" level in removing and replacing the refrigerant and oil...... is it worth the $200 gamble to replace the coil only or should i spend the $150 on a compressor and replace the whole thing?
Personally I would change both and keep the small fan as a spare. IDparts typically sells good products (even if cheap/Chinese) and for that price I don't think it's risky, no?Just ran this test a few weeks back and found the main fan dead. I had recently noticed that doing some high passes in high heat my normally rock solid temp gauge would creep up a bit.
Pulled out the main fan, pulled the motor apart and found the brushes stuck and brush holders deformed and a mess. Cleaned it up and got it working but its just a patch job so I think a new fan is going to tag onto my next IDP order.
Curious, has anybody give any feedback on the Large/Small fan complete kit? https://www.idparts.com/dual-cooling-fan-assembly-a4-p-10375.html
Given the desert climates and mountain pass stuff that I do, can't imagine the second fan is in too good a shape, might make sense to just change them both?
Martin
